Gear selector window, looking for some advice from the pro's here
Old Dec 31, 2009 | 07:39 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
I have a backlit shift plate from an 89 iroc-z, the selector window is pretty scratched up, paint missing yadda yadda yadda. The plate is pretty clean, andone know where to get a replacement window or has anyone made/repainted tier own???
Old Dec 31, 2009 | 08:19 PM
Drew's Avatar
Re: Gear selector window, looking for some advice from the pro's here
Nope, never.
https://www.thirdgen.org/shiftindicator
Your's is far enough gone, you'll probably want to find a way to back mask the PRND321 lettering. A shop that makes vinyl signs could probably make you up a mask.
Old Dec 31, 2009 | 08:30 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
what would be amazing was if i could find some of the material and make my own as it is throughly scratched on the top side. thanks for the info drew! may just do that for the time being
Old Dec 31, 2009 | 08:34 PM
Drew's Avatar
If you're carefull you could probably seperate the clear plastic indicator from the rest of the shifter plate. Then just get a piece of clear plastic from the hardware store and make a new one.
Old Dec 31, 2009 | 09:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The berlis have a nice one.Looks blue when lit, black strip with white lettering.
Old Dec 31, 2009 | 09:46 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
this one lit up blue also, im going to be changing that to red though
or maybe just make the indicator dark red to match the car!
oh and some white paint on the strip underneath white to get the white lettering
Old Jan 1, 2010 | 12:53 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Someone was selling replacement aftermarket shift indicators on ebay, but this was a few years ago. They offered different colored ones; blue, silver, red, yellow, etc.
Did you read this:
Old Jan 1, 2010 | 01:19 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
yes, however it is heavily scratched on the outside as well. i would like to fix that also
Old Jan 1, 2010 | 05:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I had a fellow member make me a new one - he was local and worked at a sign shop. It's like transperancy film that he made into the shift lettering. Then I repainted the red indicator dtripe with some testors red paint. Any signshop will be able to remake for you like I did, and for under $20. Just stop in a local sign shop and show them what you want.
1992 Trans Am
May 10, 2023 07:19 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
