shift indicator from orange to blue
Old Jan 10, 2010 | 09:08 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have changed my four gauges to blue no problem on my 88 trans am gta but i was wondering how do i change the shift indicator from orange to blue....... i want to keep my heater controls orangish red and my indicator blue to match my radio which is blue and orangish red..... thanks in advance.
Old Jan 10, 2010 | 05:11 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: shift indicator from orange to blue
On my Camaro, it was easy- remove the shifter ****; remove the torx screws holding the plate down; shift the trans to a position so that you can lift the plate up far enough to get at the bulb; grasp the bulb holder(the wires coming out of it should make it obvious) and twist and pull- it is a bayonet mount.
Swap out the bulb, reverse proceedure and drive away all 'blue'!
Old Jan 10, 2010 | 05:31 PM
RU1NER's Avatar
I didn't even need to take the **** off when I ran my iPod cable and put the indicator bulb back in (It fell out somehow?).
Old Jan 10, 2010 | 05:43 PM
88fastgta's Avatar
no i mean changing the color from the stock orange to a different color like blue.... like led lights
Old Jan 10, 2010 | 06:29 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I'm pretty sure you can just put a blue light in and be done. That's what the PO of my firebird did, although they changed the color to red, so it might be different.
Old Jan 10, 2010 | 06:31 PM
88fastgta's Avatar
i think there is an orange film or something there to give it the orange look
Old Jan 10, 2010 | 06:59 PM
hmmmm, well I suppose if you put a blue light in it would look purple, I think. But you said you changed the lights in the instrument cluster without a prob, wouldn't there be the orange/amber tinting on the gauges too?
Old Jan 10, 2010 | 07:01 PM
88fastgta's Avatar
no the lights were orange because on the light bulbs there were orange "condoms" on them.... so i went to pep boys and got blue "condoms" and changed the color from orange to blue..... looks pretty sweet.... blue dash but i have orange needles.... the two tone looks really good and matches my radio....
Old Jan 14, 2010 | 06:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There is a 1/16" thick sheet of orange plastic inside the shift indicator. You can't change the color on this (unless you want it red like I did) without replacing it. In order to do this, you have to get the plate out, undo the 2 bolts holding the indicator to the plate, and separate the 2 layers of plastic. I suppose you could try getting some plexi and using a blue light bulb or something. When you reassemble, you can either use white spray paint on one side (scratch up the surface of the plexi to paint and tape the other side), or you can do what I did and sandwich a piece of paper in the middle. I used exterior window plastic tape to put mine back together, but I guess you could use epoxy if done right. Mine hasn't come back apart in 6 years since I did this, though.
Old Jan 14, 2010 | 06:21 PM
88fastgta's Avatar
thanks for the reply...hey maverick how do i get red without changing anything....... i dont want orange....
Old Jan 14, 2010 | 06:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I went the super-cheap route and used one of my Testors paint markers... It didn't come out too bad, but it would have been better if I masked off one side and sprayed the other with a coat of Testors Gloss Red...
Camaro guys have it easier as they just change bulb colors and go... They have standard 194 bulbs, and we get the crappy ones they use in the radio and HVAC control head...
:edit: Oh, and don't forget to sand the edges of the indicator before putting it back in the light housing... Glue or whatever you use won't stick to the paint. Forgot also to mention that you have to sand the factory white paint off of the plastic as well.
Old Jan 14, 2010 | 06:28 PM
88fastgta's Avatar
yeah i noticed that... maybe they have those bulbs at pep boys..... i wouldnt mind red... but i really cant stand the orange shifter..
Old Jan 14, 2010 | 06:30 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You can go to a place like Lowes and get a really small piece of plexi for dirt cheap (I got a piece that was around 24x36" for about $20), and make it whatever color you want.
Old Jan 14, 2010 | 06:35 PM
88fastgta's Avatar
i just might do that.... thanks man....
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Linson
Sep 21, 2015 01:08 PM
gta892000
Sep 16, 2015 12:37 AM
