NOS 82-89 CAMARO 145 MPH SPEEDOMETER
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Ok, I needed to buy a new speedometer and found one on Ebay that was stated as NOS (new old stock). Now the rest of the description was kind of a trip since I don't recall a pre-1991 B4C Camaro especially since the guages changed in 1990. Here is the description and pic:
"YOU ARE BIDDING ON A GENIUNE GM PART # 25084346. THIS IS A POLICE CAR SPECIAL 145 MPH SPEEDOMETER THAT IS BRAND NEW IN THE BOX. IT FITS ALL 82-89 CAMAROS. THERE IS A REASONABLE STARTING BID AND NO RESERVE! INSURED SHIPPING IS $15 & WE ACCEPT CHECKS, MO'S & CREDIT CARDS. EMAIL WITH ANY QUESTIONS."
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: NOS 82-89 CAMARO 145 MPH SPEEDOMETER
JamesC
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
IIRC the 145 speedo came out with the 350 in 87.
I bought a NOS Tachometer last year, wife installed it for me while I was away. Works pretty nice...
Car: 1987 Camaro LT
Yea I kindda figured it would just be a standard unit. No big deal, at least (hopefully) it is NOS and my trip will work and not have to use a repair technique for the broken j clips. I'll re use my blue high beam from teh existing one in my car.
Car: 1987 Camaro LT
Late 86 apparently and many 305's were equipped with them.
What a wife, Tobias! Shoot, mine hasn't washed a car in our 40 years together (she'd say I've never washed clothes or cleaned the toilet. Can't argue, darnit!).
JamesC
JamesC
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
The 145 speedo went into production in mid-model year '86. Also, the original replacements (like above) did not come with the blue lens for some reason.
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Does this nos speedometer come with the speed sensor wiring? My 89 camaro has the 115 mph speedometer and the behind it has wiring with a yellow box behind it that connects to the tach. Hopefully you can shed some light on my question before i purchase that nos part.
Thanks for your help! One last question will i have to do any recalibration?
Ok i put the speedometer on yesterday, and it works great! The only thing wrong is that it reads 10 mph faster, is there any way to fix that?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
That sounds like the driven gear in your tranny are not correct. Did you change rear-end gears?
The car has 3.08's and a M39 t5 trans but i plan to install a J65 gt4 axle soon. i am pretty much lost on what type of driven and drive gear i need to install
JamesC
I just took my speedometer off the car and it has the red driven gear which is the 9 tooth. The drive gear is the 22 tooth, and I am running the stock 26 in tires on my stock 15 in irocs.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
IIRC,before the 145 speedo made it to production cars,
GM had a 145 speedo avalible from dealer parts
"for off road use only"(LOL)that had a single ended
needle in the tapered '82-84 style and the speedo had
a z28 logo on the face-one of those would be cool to find
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Engine: that I like
I have that one too, for my '85 IROC.
They were still available new for quite a long time, Paddock still had them in '01. I'm not sure if anyone still lists them in their catalogs now.
I recall seeing them in Classic for a period as well. I see them for sale from time to time.
JamesC
JamesC
My speedo is dead, so im going to look for a new one that reads the 140, my 87 firebird has a dead stock 90mph. Any tips I should know to make sure it fits/ reads correctly for my car.
Any ideas or were i might look to see if the trans am model works?
http://cgi.ebay.com/ebaymotors/87-88...item1c16d73e36
Btw all worked on trans am model, exsept for the trip odometer and the odometer. ended up being wires getting cut open on some medal far behind dash.
Car: 1984 Z28
Engine: 355 Injected Tunnel Ram, T76 Turbo
Transmission: FB 4L80E
Axle/Gears: 3.45 Ford 9"
Is it 10mph off across the board? If so you need to pull the needle off the front and put it back on in the right position, it can be tricky though to get it right, just keep trying.
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
