Ideas for Gauges 1991 Z28
Old Jan 26, 2010 | 11:25 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
My gauges are definitely screwed.. the only one i can really trust is the tach
i had planned to go with a nordskog dash but they seem to have gone so does anyone have ideas or pics of how i can replace the gauges?
Thanks in advance
Old Jan 26, 2010 | 11:49 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Ideas for Gauges 1991 Z28
the tach in these cars isn't even worth trusting. the one in my 91 z28 vert reads about 200-300 higher than what my scan tool shows. unfortunately, those of us with the 90-92 dash are sort of screwed in regards to any kind of replacement gauges. you can run aftermarket ones, but will need to fabricate a custom cluster and wiring for it.
Old Jan 26, 2010 | 11:26 PM
Bungle's Avatar
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Well at least the tach is close..
the speedo only decides to work occasionally and then i could be cruising at anywhere between 20 and 80, the oil pressure gauge dips to zero on a run but I know thats the sender, temp gauge jumps around like its had too much caffine
The digital dash seemed to have everything.. including the senders and a performace computer.
But you are right we do seem to be left out of the market
Old Jan 26, 2010 | 11:35 PM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
By comparison, my cars doing well. Fuel gauge hasnt let me down yet, and I've had it almost all the way to "E"nough before. I'd rather it read E with a quarter tank than a quarter tank with no fuel. Temp gauge reads well, and I've seen it go from peg to peg in an afternoon (Stupid water pump). Oil pressure gauge reflects what a scan tool reads, so im happy with that. Tach is a couple grand high, and the speedo doesnt work. But who really needs to know how fast we're going, eh?
Old Jan 31, 2010 | 01:32 PM
Bungle's Avatar
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
no one with ideas or pics? does everyone run stock gauges??
Old Feb 5, 2010 | 06:28 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I'm currently in the process of doin the aftermarket gauges with custom cluster. I took my stock bezel and fiberglassed over it, I got caught up in the body work of the car and gettin it swapped over to carburated so I kinda put it on hold. But I picked up a set of digital gauges, a guy at the local speedshop said that I can just find out which plug controlled what then make connectors and just plug and play. I may have them just install them for me after I get done makin th bezel. But I've got a lot of work to do to get the bezel just right before I go to install em
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Cripley
Aug 17, 2015 03:35 PM
Jlanz55
Aug 17, 2015 07:15 AM
