Dome light
Old Jan 30, 2010 | 05:31 PM
evol's Avatar
Car: 1991 Z28 camaro
Dome light
Today i was putting in my new speakers in the sail pannels and i realized that my dome light wasnt on i was just wondering how to get the white plastic cap off to see if its burnt out or if i hit a wire somewhere. Also the wire that runs up to the dome light where does it run to from the dome light?
ty for help
Old Jan 30, 2010 | 05:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Dome light
just grab with fingers and pull the white cover off.
its tab clicked into place into the black dome lamp base housing,
the orange wire to the dome is full time hot
the white wires run through many things including door switches and headlamp switch/interior lamps dimmer rheostat assembly and sometimes a timer control module is involved, and it goes on from there.,.,.,
the white is switched source ground.,
fuel sender guages circuits work the same basically, hot all the time with ign switch in run position though, and ground controlled by components.
its kinda complicated and i cant explain it any better than that
most ppl dont understand the dome lamp circuitry and how it works, many different components are involved with it and its just too much to type.
probably are lots of pages out there with pics and long descriptions about it
check your interior lights fuses, or test light the orange wire it should be hot all the time., if not then you got a broken wire or bad fuse, or something else. see if the white wire is grounded good with a door open, if not then you got z broken wire or bad door switch or bad connector somewhere.,
Old Jan 30, 2010 | 05:36 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: Dome light
Are the lights in the floor still working? And to remove that cover, all you have to do is mash the sides or back in a little bit (depending on where the little clips that hold it on are) and pull it off.
Old Jan 30, 2010 | 05:51 PM
evol's Avatar
Re: Dome light
No there were no floor lights
Old Jan 30, 2010 | 05:57 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Re: Dome light
How about using the dimmer switch for the gauge lights? Does that turn them on when it's all the way up?
Old Jan 30, 2010 | 06:04 PM
evol's Avatar
Re: Dome light
Nothing
Old Jan 30, 2010 | 06:09 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Re: Dome light
I doubt it's the bulbs. It's either a short or the fuse is blown.
Old Jan 30, 2010 | 06:14 PM
evol's Avatar
Re: Dome light
Is there any wires that run behind the sail panels where the speakers sit or behind the radio its self? ill also have to go and check the fuses quick
Old Jan 30, 2010 | 06:17 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Re: Dome light
Shouldn't be anything in the sail panels, but behind the radio there might be, but when it comes to which wire, I have no clue. XD
Old Jan 30, 2010 | 06:28 PM
evol's Avatar
Re: Dome light
btw wat fuse would it be inst lps?
Old Jan 30, 2010 | 06:49 PM
evol's Avatar
Re: Dome light
Also the light in the back window what makes that come on is that a brake light?
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
