Post Those Odometer Numbers!
Old Feb 8, 2010 | 10:10 PM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Third gen cars are between 28-18 years old, so i'm wondering if anyones gone 999,999 miles in one.
Post your odometer numbers to see who is the closet to it!
Mine is 211,XXX.
(rebuilt motors, and transmissions count )
Old Feb 8, 2010 | 10:22 PM
veritas91's Avatar
Car: 1983 Firebird
Engine: 327
Transmission: 5 speed, stock
Re: Post Those Odometer Numbers!
84,xxx on my '83 Firebird. Not to shabby I think
Old Feb 8, 2010 | 10:23 PM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
49,568
The original owner let it sit for YEARS without driving it... His loss is my gain!
Of course because of that the transmission needed a rebuild but still well worth it!
Old Feb 8, 2010 | 10:25 PM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
Cars in storage for the winter, but I believe Im just a few hairs shy of rolling over 150,000km. Its' a 1991, and Im the third owner.
Old Feb 8, 2010 | 10:36 PM
B'tx's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual
92 Camaro RS: 210,860 mi
No engine/trans rebuild, thank you...Still running good
Old Feb 8, 2010 | 11:46 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
281,7xx miles and that's on one 2.8 v6. Doesn't burn oil, leak oil or anything else for that matter, but the exhaust is shot and the camshaft has a worn lobe causing noisy lifter. Otherwise it runs great.That's what happens when ya take care of a car folks, I've got service records all the way back to 1986. I had to replace the tranny though
Old Feb 9, 2010 | 12:34 AM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
Transmission: slugomatic
I turned 222,222.2 this fall. Ill check and see where she sits now... All stock T/A. 305 700r untouched, I throw an alt and a starter at it once in a while. My Dad has a 94 1500 305 700r, so pretty much the same vintage, 395,000, burns a little oil on start up...runs like a top.
Old Feb 9, 2010 | 12:43 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
This is from a couple months back - The engine and trans were supposedly rebuilt at some point, but I have no proof. I've replaced the alternator, A/C compressor, water pump, injectors, and lots of other minor things.
Old Feb 9, 2010 | 01:24 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
1991 Z, 69,167
Old Feb 9, 2010 | 05:00 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
77,452
can't say for sure if there should be a 1 in front of that or not, need to find the previous owner and see where it was at 10 yrs ago when he had it.
Old Feb 9, 2010 | 07:35 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Originally Posted by Purple82TA
77,452
You could also pull a carfax report. The mileage shows up for each inspection and title transfer.
Old Feb 9, 2010 | 07:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I rolled the odometer on the IROC over the summer... I'm probably at 100,010 or so now.
I think my GTA is right around 141k or 142k.
Old Feb 9, 2010 | 07:52 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
188,310
Old Feb 9, 2010 | 08:13 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
My purple 92 has 64k and some change on it
Old Feb 9, 2010 | 08:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
150,000 or so.
JamesC
Old Feb 9, 2010 | 09:42 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
181,731.2 on mine . it's a true daily driver . very mild mods. .
Old Feb 9, 2010 | 09:50 AM
LTL_DMON's Avatar
Car: 1986 Trans AM
Mine stopped working at 126,804 bought it that way.
Old Feb 9, 2010 | 10:05 AM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Mine just rolled over for the first time with me. It only reads in the ten thousands. So I did some math... It's 25 years old. If it has an average of 11 thousand miles a year i have just hit 300,000 miles! If it has an average of 16 thousand a year I just kit 400,000! I have put about 40,000 miles on it in about two years so if it went an average of 20,000 miles a year, I just hit the 500,000 mile mark!!!! Still an all original motor and trans with headers and exhaust, but I did replace the rear diff when it gave out! I guess theres no way of knowing for me. Or is there??????
Old Feb 9, 2010 | 10:09 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
104,500
Old Feb 9, 2010 | 10:17 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
My 84 camaro is currently at 187 241.
Jhook's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0
1991 Z28, 104,365.3
Old Feb 9, 2010 | 10:50 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
76,0XX. Odometer has not been rolled over. All orig., never modified.
Old Feb 9, 2010 | 10:54 AM
kcb37's Avatar
Mine is at 122,xxx of course it was when I bought it. Haven't put a speedo cable in cause it won't be right anyway. I figure it's a good way to keep the resale up.
Old Feb 9, 2010 | 11:10 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
43,000 for me. Owner bought car and then it sat in driveway for years while he played with his other toys. Car paint is in rough shape and looks like it has over 200,000. Southern paint job I was nervous driving her home since odometer stopped working for a bit. Now my speedo is acting weird so another project for me to fix when it gets warm. Good to see so many nice looking, high mileage thridgens!
Old Feb 9, 2010 | 11:21 AM
worldman100's Avatar
275,135 ON MY 83 Z28 ALL ORIGINAL AND RUNS GREAT
Old Feb 9, 2010 | 11:41 AM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
1988 5 speed GTA 20,000
Old Feb 9, 2010 | 12:44 PM
CamaroDude90's Avatar
Car: 1989 Camaro RS
Engine: 2.8l V6
84,831
Old Feb 9, 2010 | 12:58 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
130k on the body needs paint soon, 2k on new motor and tranny
Old Feb 9, 2010 | 01:08 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Odometer rolled twice that I know of so...at least 200,000 miles. She now has 26,001. The 1 mile is when I had to go to the gas station to fill her up lol with her new engine. I want to drive her already, but gotta wait to pay for dmv paperwork argg.
Old Feb 9, 2010 | 05:51 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
92 RS 135k and still running strong.
Old Feb 9, 2010 | 06:24 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
85 t/a tpi
either 77k or 177k i just recently bought the car and i have no clue
wishful thinking says 77 but it may actually be 177 im gunna rebuild her soon so i should get a better idea
Azrael91966669
25
Jun 20, 2017 04:04 AM
Chuck84TA
Jul 15, 2016 09:05 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kyle5647
Aug 7, 2015 03:08 PM
