91 SPEDO TO AN 85???
Old Feb 22, 2010 | 12:20 AM
jls172008's Avatar
I HAVE TWO THIRD GENS A 91 FIREBIRD (WRECKED) AND AN 85. THE 85 HAS THE 85 MPH SPEDO, THAT DOESNT WORK BC THE TRANS I PUT IN THE CAR HAS AN ELECTRIC PLUG, SO THE MANUAL GEAR DOSENT WORK. HOW MUCH TROUBLE WILL SWITCHING THE DASHES BE? ANY HELPFUL TIPS WOULD BE GREAT!!!
Old Feb 22, 2010 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 91 SPEDO TO AN 85???
Remove the VSS from the donor trans, install a speedo sleeve (gear housing) along with the the correct drive and/or driven gear, install the cable and drive into the sunset.
You'll find the sleeve and gears at the following site:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Old Feb 22, 2010 | 05:41 PM
jls172008's Avatar
could you break that down a little more vss?
Old Feb 22, 2010 | 05:52 PM
JamesC's Avatar
The piece that bolts into the trans on a car equipped with an electronic speedo is the VSS (vehicle speed sensor). Simply remove it and bolt in the pieces designed for a cable-driven speedo.
JamesC
grngryoutmyway
Nov 15, 2003 09:33 PM
Gumby
Oct 5, 2003 03:01 PM
87cam305
Aug 18, 2003 03:49 PM
94'_SS
May 24, 2002 07:12 PM
