91 T/A power seats don't work
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I have a 91 Trans Am vert with manual seats however they have the power inflatable bolsters with the 4 buttons on the side of them. They don't work at all for me. Fuses are all good. What can it be?
Transmission: Pro-built 700R4
Re: 91 T/A power seats don't work
Start simple. You've already checked the fuses. So he next two things I would check are:
Have you checked to make sure the electical lines beneath the seats are connected?
If so, did you check the air hoses under both seats? Check to ensure they are both connected and don't have any cracks/leaks in them. If the lines are not fully connected on both seats, they won't work at on on either side.
Engine: LB9
Engine: LB9
I have not actually, I'll have to get one or borrow one from somebody. So the wires in the floor always have juice sent to them, or at least are supposed to? Considering that the switch is on the seat...
corrosion is like dust...its everywhere!get some contact cleaner and clean all electrical connections
especially the contacts inside of the switch
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Even with an airline disconnected you'ld hear the pump, plus any air escaping.
Have you tested the airpump(straight to batt) to make sure it works?
Sometimes the fuse is on the harness, under dr seat.
There are relays too, check those.
Power is "hot" (all times),seats function even if ing is off.
Ive had the switch itself go bad on once, but not both together.So it has to be a common connection.
Engine: LB9
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
