Turn signal problem
Old Mar 8, 2010 | 01:32 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
Turn signal problem
So if any one can help if been fighting this for bit. I cant turn my brights on unless the stering wheel is all the way up. and if is is in any other position then it just goes back and forth and dosent engadge so is it the sterring column or the switch please help if u can.
Old Mar 8, 2010 | 05:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Turn signal problem
It's the high beam switch - it's located at the bottom of the steering column, above the brake pedal. It is adjustable - take the under dash panel off, lean the seat back all the way, get in upside down with feet at headrest and face up with a flash light and a 7mm socket and handle or rachet with extensions. You can tell which one by moving the lever and watching for the moving rod - loosen the bolts just enough to slide the switch very minimally up towards the steering wheel, retighten (easy here - they strip easily), and check.
Old Mar 9, 2010 | 08:15 AM
B'tx's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual
Cool! I have the same problem. I'll do just that and see if it fixes the problem. Thx!
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
