Rusted Floor Pan, Need Interior Help.
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
I have a rusted floor pan and I need to know what I have to take out of my car to get to it...its on the drivers side. I know the seat and the carpet need to get taken out but what do I need to remove to get the carpet out?? Thanks
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
Re: Rusted Floor Pan, Need Interior Help.
same problem but my seat bolts are seized on and the tracks are seized and my seat happens to be all the way back and no idea on how to get the back nut off or anything, let me know how you make out
Engine: 305 TBI
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
You'll have to remove the center console, seats, both lower seat belt mounting points for the front seat for both sides, plastic sill plates, and the kick panel trim. Its easier if you take the big trim panels off behind the door too but you probably can get it out without taking those out.
Engine: 305 TBI
Engine: 355 chevy
Transmission: t-5
yeah, i have a question about the console, i removed the top part so only the console housing is left. i tried to see if anything was holding it down but couldnt find anything, but i couldnt pull it out either...is there something i am missing? what could i have missed?
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I had a small felt piece covering the bolts inside the center console. Removed this and it revealed the bolts in the center console.
Engine: 305 TBI
...you should Thread Starter
Engine: 305 TBI
...im gonna document my rebuild of my car with pictures and some sidenotes...let me know if u get ur seat off Thread Starter
Engine: 305 TBI
I have the same problem, my car lit on fire so i riped all out besides dash and counsol, What yah need to do from my perspective is loosen the wires runing along teh rockers and cover them with a strong flame resistand materisl. Remove some of the fire wall pading and insulation, cover the counsel also. Weld from the bottem so it will not leek any more. Basicly just cover anything that will be hit by sparks or heat and weld from bottom. Make nice even cuts from the rust just about an inch back from the good steel. Cut the patch evenly in the direct shap and make sure it fits tight, the tighter the fit the less gaping you have to do with the welds. Use a mig with gas not flux core. Tack it in, than stich it in, than compleat the weld. coat it with some primer and than an under coat. For the top you can weld it in but more risk of fire, or you can use some calking seelent that is of good grade and will last a while and is resistant to weather. the selant also works for any loose drain plugs. Ive been training with body work and am talented with welding, these are the steps im takeing for my car, and I have had expert welders give me tips and tell me how to do it specificly. Good luck and always keep a fire extingrusher on hand.
Engine: 305 TBI
ok guys....i have removed my console and its housing, my seats and my rear seats, but not the back...what else do i have to remove? i thihnk i might have to take some paneling on the side off...WHATTA DRAGGGGG lol i dont mind but it gets annoying
ambainb
Apr 25, 2016 09:21 PM
