Gauge cluster issue
Old Mar 25, 2010 | 06:18 PM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Gauge cluster issue
Everytime I put my right signal on, my tach, volts and oil pressure gauges go out. Took it apart but couldn't find a problem...plus when I turn on the cluster lights it does it....Anyone ever had this problem?
Old Mar 25, 2010 | 09:42 PM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
Re: Gauge cluster issue
i have a similar problem. when i turn my dash lights on everything just peeks or drops all the way down. my rpms peek. my volts drop and gas gauge doesnt work. And also my right turn signal always wants to stay on?I wish i could help you to fix the problem but im still trying to figure it out myself. if you or anyone has some advice that would be great!
Old Mar 27, 2010 | 12:11 AM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
check the ground strap from the firewall to the motor
Old Mar 27, 2010 | 09:55 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Where is that located?
Old Mar 27, 2010 | 09:58 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Mine does the same thing except my fuel gauge isn't affected. Right blinker light just stays on..
Old Mar 27, 2010 | 10:03 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
if you look right above your distributer on the firewall the should be a bolt screwed in the fire wall with a braided wire attached to it thats the ground wire it goes from the firewall to the back of the engine good luck !
Old Mar 27, 2010 | 11:30 PM
84 Kamp311's Avatar
Engine: 406
behind the distributor, its a bare braided flat wire that goes from the fire wall to the block or intake bolt
Old Mar 28, 2010 | 09:41 AM
86' Camaro's Avatar
Car: 1986 Camaro Z-28
Engine: 305 TBI
I have a similar issue where when i turn my car on, my volts gauge is bouncing up and down in the middle of the gauge, my gas is off my a 1/4 of a tank, and my temperature gauge is pinned at the bottom. I've just decided to change the sensors.
Old Mar 28, 2010 | 10:30 AM
84 Kamp311's Avatar
Engine: 406
I said the hell with it and just changed the gauges, a little pricy but damn looks good. A black piece of lexan, some hole saws, and some home work tracing wires. Works no diming of lights no gas gauge sticking
Attached Thumbnails Gauge cluster issue-auto-meter-gauges-001.jpg   Gauge cluster issue-auto-meter-gauges-002.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
