how do you deflate the lumbar seats? switches don't work !!!
Old Mar 29, 2010 | 07:19 PM
stan12777's Avatar
ok, its a 91 TA, both seats the lumbar on the don't work, and i think the driver seat is stuck inflated and i wanna deflate it somehow manually, plus is there a fuse for these seats?
Old Mar 30, 2010 | 06:13 PM
stan12777's Avatar
Re: how do you deflate the lumbar seats? switches don't work !!!
is there a fuse at least for these seats?
Old Mar 30, 2010 | 06:16 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
***edited because stephen cant take a joke and threatened that if I dont edit my post that it would be edited for me***
Old Mar 30, 2010 | 06:28 PM
Stephen's Avatar
Car: 87 GTA
C'mon people....Let's provide a REAL solution, not just a way to destroy the seats.
Might try on the Electronics board, since the techies hang out there & this deals with the electronic controls.
Good luck!
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Reach under the seat and unhook the air lines......?
Old Mar 30, 2010 | 06:31 PM
Car: 89 formula 350
Good luck!
Old Mar 31, 2010 | 01:17 AM
stan12777's Avatar
yeah i guess ill try the electronics section, thanks anyways guys.
Old Mar 31, 2010 | 06:35 AM
Car: 86 Trans AM
Wait so unhooking the air lines isnt a good solution? That dumps the air does it not?
Or am I not understanding whta you want. Do you want to deflate the seats...or FIX the seats. If you want to deflate them pulling the air lines would let the air out. They are just air bladders. If you want to FIX them, then the electronics section will help, and I can give you some pointers.
There are usually breakers for the power seats. So that for instance if you held the button forward until the seat reached the end of the track, and kept holding it, it would trip the breaker instead of blowing a fuse. Those breakers CAN go bad...so there's a place to start. It could be that the switches are busted, or a power wire is broken somewhere. You really gotta dig in and start testing things out.
J.
Old Mar 31, 2010 | 08:17 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
The fuse for the seats is an inline fuse located under the driver's seat.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
dhonda200
Aug 11, 2015 11:50 PM
Fronzizzle
Aug 9, 2015 01:15 PM
