Interior parts (radio delete plate etc)
Old Apr 12, 2010 | 01:44 PM
steNcho's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Hi guys, I'm looking for some interior parts. I need a radio delete plate. I have made my own but I really like the look of the factory delete plate. I also heard that 1LE cars had block off plates where the A/C vents normally are. Where could I find these? I would also like the lights switch bezel without the hole for the fog light switch so I can mount my nitrous arm switch and purge button there. Thanks!
Old Apr 12, 2010 | 08:53 PM
steNcho's Avatar
Engine: 355 SBC
Re: Interior parts (radio delete plate etc)
Anyone?
Old Apr 22, 2010 | 04:32 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
the 82-89 Camaro non AC dash, is the same as the 1LE dash. The vents do not have block off plates you can purchase. The dash simply does not have the cutouts for the vents. It's a solid molded piece. This is only for the side vents. The center vent is still open.
http://www.moderndaymuscle.com/inc/sdetail/665 - factory block off plate for the radio delete.
http://www.moderndaymuscle.com/inc/sdetail/1109 - trim plate with out fog light switch
Old May 18, 2010 | 09:23 AM
steNcho's Avatar
Engine: 355 SBC
Thanks a lot! Too bad about the vents in the dash. I removed my A/C equipment ages ago and the vents just flop around when I'm driving .
Old May 18, 2010 | 09:36 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can fix the flopping of the vents so that they stay in place where you set them - get self adhesive felt from the craft store, take the vents out, and adhere a piece to each outer side of the vent, then reinstall. There's a write up on it in the tech articles under beautification I believe - I did it years ago and it works great - the vents stay where you aim them.
Old May 18, 2010 | 09:51 AM
steNcho's Avatar
Engine: 355 SBC
Thanks!
Old May 18, 2010 | 09:45 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
my 82 without a/c has those blank spots... so im sure if you find one in a junkyard without a/c, you should be good.
EDIT: Also has the light option you want, i believe 82-86 had the blank ones?
Old May 19, 2010 | 09:24 AM
steNcho's Avatar
Engine: 355 SBC
I live in the caribbean and there are probably no third gens in the junkyards here. Really like the look without the A/C vents though. Mine is an 82 but one of the previous owners put a nitrous button where the fog light switch should be. I don't like how they dit it at all but if I remove the button I'll be stuck with a big hole.
Old May 19, 2010 | 01:52 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
go here: http://www.mcmaster.com/#abs-sheets/=75rl8c Under the "Finish", click on "Textured on one side" and you'll have a bunch of sizes to choose from. I haven't bought from them yet, but I'm guessing the texture is pretty close to our dashes and the prices are cheap. I bet you could make a radio delete plate and blockoff plates for your outer vents for half the cost of the radio delete plate.
Old May 20, 2010 | 03:18 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
This is what the AC delete looks like. These parts are for sale by the way. The only imperfection is where someone drilled a small hole and put a light in it. That should show in the third pic.
I also have the AC delete heater box for sale.
Old May 21, 2010 | 07:17 AM
steNcho's Avatar
Engine: 355 SBC
Really like the look :P. I'm just gonna fix my vent so they don't keep flopping around when I'm driving. My dash is pretty mint (and that's in an '82 that's lived in 90 degree weather forever). Gonna get the 1le delete plate though. I have my own made right now but I love the look of the factory delete plate. Thanks everyone!
Old Nov 12, 2014 | 08:42 AM
Tommymaro's Avatar
I know this is a old post but I an looking for a heat box for my 86 camaro if you still have it.
Old Nov 12, 2014 | 09:53 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
That was 4 years ago man, I hear the non ac box from s-10's fit but I'm not sure what years. That should be easy enough to find in a junk yard.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
