How is this caused?
Old May 7, 2010 | 07:53 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
How is this caused?
Can someone please help me out, I would like to know how this is caused, what part it is that needs to be replaced, where I can get it, price and of course, how difficult to install... Thanks in advance. I gotta do the other side also, that one is more to the front of the window tho.
Old May 7, 2010 | 08:02 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: How is this caused?
Subscribed.
Wondering the same thing. I am afraid to get tint because of this problem.
Old May 7, 2010 | 08:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Pull the door panel and take a look.
Old May 7, 2010 | 08:26 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
i'm pretty sure its the metal bracket that clips the door panel to the door, u need to take the dor panel off and bend it inward a lil
Old May 7, 2010 | 08:28 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
There's little valor covered dads inside your door that the window slides on the valor wars off and will cause that to window tint.
Old May 7, 2010 | 08:57 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
They are $17 each at your local GM Dealership, I ordered 4 on wednesday. They have a little sheet with the parts on it for the door, I believe it was a #4, if thats even remotely helpful.
Old May 7, 2010 | 10:43 PM
Copchaser's Avatar
Thanks for the info guys. I will look into it. If anymore info pops up, please let me know.
Old May 7, 2010 | 10:55 PM
Copchaser's Avatar
is it these? Window Guides?
Old May 8, 2010 | 09:31 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I believe they are called window guide felts.They mount on top of the door,underneath the black plastic trim and have soft furry material on the side that faces the window.I had the same problem on my old 82 camaro in the same place as your picture
Old May 8, 2010 | 08:01 PM
Copchaser's Avatar
found a few sets on ebay.. probably gonna ****** a few up
Old May 9, 2010 | 03:24 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
You have two of them per door. They window rides against them and they keep the window from rattling. When you install them they should have light pressure against the window. Run the the window up and down after putting them on before re-installing the door panel to check how it is.
Old May 9, 2010 | 03:53 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
well i guess i know why doors are rattling too then. wow ive got a lot to replace!
Old May 12, 2010 | 03:17 PM
hiwastar's Avatar
Good thread, I have the same issue on both windows.
Old May 12, 2010 | 03:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link details door/window rattles, for those who haven't seen it:
https://www.thirdgen.org/forums/body...servation.html
JamesC
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
