Power window switch smoking!????
Old May 13, 2010 | 04:20 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Hi all, I have a 91 bird and my driver side window has been slow for some time now. Usually it is when rolling it back up. It will be slower than the passenger side. Anyways , the other day i smelled smoke and it was coming from the window switch harness! so, i disconnected it. The plastic harness that connects to the window switch is melted a little.LOL. Also, whenever the harness is plugged in to the switch, then the power window fuse in the fuse box gets really really hot too! Wtf? Could it be a bad switch? or a bad motor? Any help/advice is appreciated. Thanks 91
Old May 13, 2010 | 04:24 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Power window switch smoking!????
id say a bad wire(s)...the wire might be exposed...maybe
Old May 13, 2010 | 04:27 PM
ninetyone's Avatar
Axle/Gears: 3:42
but bad wire where? and what wire do you mean?
Old May 13, 2010 | 04:28 PM
ninetyone's Avatar
Axle/Gears: 3:42
all of the connecting wires are still in the right spot inside the harness. The plug holes in the harness are just a little melted. Only the plastic. I thought it might be the switch, cause it looks like someone spilled something on it (it sticks).
Old May 15, 2010 | 11:34 AM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
Sounds like a bad switch.
If the fuse gets hot when the harness is unplugged from the switch, there's a short in the harness.
If the switch is getting hot without using it, it's shorting. Replace it.
If it gets hot when using it, replace the motor and don't forget to grease up the regulator assembly.
Old May 15, 2010 | 06:50 PM
ninetyone's Avatar
Axle/Gears: 3:42
How about the fuse gets hot when the switch is connected to it's harness. The window is also real slow to go up and down. I was thinking that might indicate a bad window motor? Let me know what you think. Later
Old May 16, 2010 | 02:54 AM
Engine: 5.0 LG4
Does the fuse get hot when using the window, or does it start heating up as soom as you plug it in?
Old May 17, 2010 | 08:17 PM
ninetyone's Avatar
Axle/Gears: 3:42
figured it out. It was the switch
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
