Sound Deadening
Old May 17, 2010 | 08:54 AM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Sound Deadening
I'm looking around for options on some sound deadener. Dynamats expensive, so i'm looking at cheeper options.
Ebay sells 100sq ft, of 50 mil at 90 bucks. is it worth it?
They also sell 80 mil. Is this a bunch of extra weight that i dont need?
http://cgi.ebay.com/ebaymotors/100-S...item3effd69192
Old May 17, 2010 | 09:14 AM
Twin_Turbo's Avatar
Re: Sound Deadening
I have both the thicker and thinner stuff, the thicker works significantly better but it's also heavier.
I just used the thick in most places except for the rear trunk well, the stuff w/ the blue logos is the thinner
Old May 17, 2010 | 01:15 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Sound Deadening
Try http://www.dealercostcaraudio.com/se...FRSfnAodh1zQJw
for Dynamat at half price!
Old May 17, 2010 | 02:32 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Sound Deadening
http://secondskinaudio.com/
Excellent products, good price, and top notch customer service. I'll personally never use anything else.
Old May 17, 2010 | 02:34 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Transmission: 5-Speed
Re: Sound Deadening
i went with Damplifier from Second Skin.
http://www.secondskinaudio.com
Attached Thumbnails Sound Deadening-img_4914.jpg   Sound Deadening-img_4917.jpg
Old May 17, 2010 | 02:38 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
Re: Sound Deadening
Is it pretty easy stuff to work with? Just cut, peel and roll it out?
Old May 17, 2010 | 04:42 PM
malaka's Avatar
Car: 1988 Firebird
Engine: 2.8 V6
Re: Sound Deadening
pretty much. easy, but time consuming.
Old Jun 7, 2010 | 10:20 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Sound Deadening
I bought the Fat Mat 'rattletrap' off Ebay for $159.00 with free shipping. I'm about 95% done. It will be enough to do your entire vehicle. Twin_Turbo has the same looking stuff in his second photo. And, as Malaka stated, it's VERY time consuming. If you do the job by yourself, realistically expect to spend at least 20 hours doing the entire interior. I'm actually just finishing the job today and will post photos later this week. Very tedious and unfortunately, these cars don't have many flat spots; it's all curves and contours. The below photo is of a closeup of another car but will show you how much cutting is needed as well as the fact that it won't cover every square inch; there will still be blank spaces, as shown.
A search of ebay for: 'Rattletrap Fat Mat' will show you current prices
Old Jun 7, 2010 | 10:41 AM
Twin_Turbo's Avatar
Re: Sound Deadening
Yes, the part with the blue script on it is rattle trap. It was more expensive than the other plain stuff and it's not better. It's thinner and doesn't stick nearly as well, you really need a heat gun to get it to stick on compound curves or other oddly shaped surfaces. The cheaper stuff worked a lot better for me.
Old Jun 7, 2010 | 12:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Sound Deadening
I had a big thread goin once, ill just repost what I found here.
I did go with SmittyMats in the end as it was big with the Vette crowd for its light weight but effectiveness. Got it off ebay, they got stuff listed all the time but should of used their reg store, if you search on their name you can find discount codes all over, there is a link to one below.
"Dynamat and other sound heat and vib mats: Compare
So who all is using Dynamat sound heat and vib mats???
Anyone using other brands???
Man are them things pricy.
$28 for 2 10"x10" pieces of Dynamat
http://www.dynamat.com/store/store-car.asp
Some roll on crap
http://www.quietcar.net/?gclid=CKvz9...FQIWFQodaVy9HQ
Stuff called 2nd skin that is pricy like dyna
http://www.secondskinaudio.com/
And I found smitty mats about 1/3 the pirce of them all.
http://SmittyMats.com/
Look like everyone sell the same basic stuff, those that sponsor racing and have adds on TV just charge out the BLEEP for it............ Also a friend who got dynamat form summit just the other day the salesmen said the price will be going up here soon.
Just hard to spend that much but want some comments.
Oops for got one
http://www.hushmat.com/new/ Performance/index.htm
Starter Kit - 4 square feet
$40.00
Thats 4 12x12 squares for $10 each, man do you know how many it would take to do the inide of my car???
That $2sqft stuff looks better and better.
Its also on ebay with good reviews.
Anyone have pic's they can share of a sound vib mat install in your car or what not???
And how much you spent if that not like asking a woman her age for you.
http://www.tjoos.com/Coupon/144326/Smittymats.com
Reguarding the other post, I went with Smitty for the weight issue.
As I do not need a bunch of weight only running a small 2.8 v6
http://SmittyMats.com "
Old Jun 7, 2010 | 12:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Sound Deadening
1 tip get the tape, I cheaped out n tried to use chrome duct tape the first time, which was soon hanging lose, now the sticky part of the tape was still there but the outter covering was lose, that aluminum tape that comes in the kits is awesome stuff.
Have ordered twice now.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
