Hatch / lock Help Needed
Old May 22, 2010 | 04:23 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
Transmission: automatic
my '92 Firebird rear hatch w/ pull-down unit had been working properly until .... it was returned to me w/ key as shown;
the key wont turn and is just short of the release position.Removing the rear panel is impossible with the lid closed.The car has no interior release button etc.
Any help will be greatly appreciated!
Cheers.
"Mad" Matt "J"
'92 Firebird
Old May 22, 2010 | 06:57 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Re: Hatch / lock Help Needed
wow wtf happened? btw i wouldnt let who ever used your car, use it again lol. hmm did you try to just pull it out? could try to spray some wd40 around the key, maybe the lock got stuck...or use pliyers to turnt he key to release the hatch.
Old May 22, 2010 | 07:19 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
DARKmj16;
I hear you there!
Since I wasn't there when this happened I'm not sure what all was/ wasn't done and I'm not sure what to think.
Tried the WD40, pliers, "force it" already as well most related recommendations from the forums. Crawled into the trunk area to search for access to the pull-down unit / lock but the panel cannot be removed w/out having the hatch up (there's some for-thought G.M.!). Hoping someone here has been in similar circumstance.Right now I'm learning to live w/out a hatch.
"MM"
Old May 22, 2010 | 07:24 PM
DARKmj16's Avatar
Engine: 305 tbi
lol ya the top of the panel has screws in it. hmm. well if you have another key and dont mind repaceing the lock...tie the key to something (like a tree) and drive off... then the inside of th elock will be open and maybe a screw driver can make it work. but i would ask some ppl b4 doing it, as im not to sure what could happen doing that way.
Old May 22, 2010 | 07:35 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
DARKmj16;
we must have gone to the same school of auto mechanics ...
it may come down to that but if I can avoid it I'd rather save the $$ for the next thing that needs to be fixed on it.One project at a time.
"MM"
Old May 22, 2010 | 07:50 PM
DARKmj16's Avatar
Engine: 305 tbi
lol i doubt it, my auto teach was a complete moron, he holds 4 ASE and still dropped a car on himself.
Old May 23, 2010 | 08:36 PM
my82roc's Avatar
Car: 89 Iroc Convertible
You can access the hatch motor if you have a courtesy light in your center hatch panel.Just pry out the light assembly and you can either pop the hatch by turning the mechanism with a flat bladed screwdriver or by tugging on the cable that goes from the motor to the lock cylinder
Old May 23, 2010 | 10:08 PM
DARKmj16's Avatar
Engine: 305 tbi
oya i forgot bout that, try this first lol.
Old May 23, 2010 | 10:48 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Done this a few time myself. Really handy to open hatches in the boneyard with no key available.
Old May 27, 2010 | 04:44 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
Sure enough ... hatch popped right up. Now to fix the screwed up lock mechanism and get the key out of it. If it would just stop raining ....thanx for the help.
Old May 27, 2010 | 09:20 PM
my82roc's Avatar
No problem...Glad to hear it worked for you
Old Jun 8, 2010 | 01:22 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
Here we go again .... have the lock assembly on my desk w/ key still stuck in it. Just back from the local locksmith who quoted $25.00 to remove it.
Any one have any ideas how to get the key out before I'm forced to pay his extortion or just destroy the thing trying to get it out or just destroy it in a rage?
Thanx!
"MM"
bad pics.the key is stuck all the way to the right
Old Jun 8, 2010 | 01:27 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
is there any way to take the lock apart?
Old Jun 8, 2010 | 01:51 PM
MadMatt's Avatar
Car: 1992 FireBird
Engine: v6
As far as I can tell the key has to be out in order to disassemble it.Great.
If the key would turn (it wont) it would slide right out then the cover would turn and come off then the rest rotates and comes out. Other than drilling, cutting or .45 caliber shooting the key off I don't know how to remove it.
I've tried to force it, clean it out, listen for some loose parts (nothing) even dragged a magnet hoping to loosen or move whatever is out of alignment inside the barrel. No results.
Hoping to some help before I have to destroy one of the parts in order to get it apart.
Old Jun 8, 2010 | 01:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Is it turned back to the in /out position, they don't often come out if stuck in the turn.
Id ask is it $25 to remove it and have both the key and lock work right once done or just get out the key.
Cause you could destroy the lock n save the key yourself.
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
