Single Key Retrofit???
Old Jun 3, 2010 | 10:26 PM
Road Rash Ninja's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: TPI 350
Transmission: Beefy 700R4
Axle/Gears: Stock, don't have a clue
Is it possible to leave the double key system and move up to a single key from the 4th gen camaros? are the locking cylinders even close enough to swap out? I figure the newer keys require longer cylinders. Just curious.
Old Jun 3, 2010 | 11:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Single Key Retrofit???
Maybe the 1998 later cars had single keys, but my 1997 Z28 has double keys just like y 1992 RS
Old Jun 3, 2010 | 11:53 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
If you have t-tops that lock, you're talking about swapping 6 total lock cylinders, 7 if you have the locking storage cover over the trunk well. The seems like a lot of work when two keys fit on one ring. I would think you would be able to do it, just a matter of keying all the cylinders the same. But like I said, it seems like a whole lot of work
Gunner242
Dec 25, 2015 04:49 PM
LT1Formula
Oct 8, 2015 08:34 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
