85 sterring wheel swap back to stock
Old May 20, 2010 | 10:31 PM
terl30's Avatar
Car: 1990 Iroc,02 ws6,74 corvette
I have a 1985 z28 and when i purchased it, it had a chain link sterring wheel. besides being hideous it is small and difficult to use. i removed the 3 retaing screws and big center and when i put the new(just purchased stock wheel and horn button)on it was too big and would not line up. my question is...........is their an adpter plate from facoty on these? i have searched and cannot find any illustrations of what a stock wheel looks like with horn button off.i know im not explaing this correctly but hard to put into words i appreciate any help i cana get.
Old May 20, 2010 | 11:42 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 85 sterring wheel swap back to stock
The stock wheel slides onto the shaft, and gets tightened down with the nut in the middle. There are no "3 screws" that hold it on, thats just the way that aftermarket steering wheels connect. Remove the adapter that the aftermarket wheel used to mount to the column, and it should slide on, then tighten it down.
Old May 21, 2010 | 08:41 PM
vette gator's Avatar
Car: 85 Z28
As a fellow 85 z28 owner, I threw up in my mouth a little when I read this.
Old May 22, 2010 | 08:20 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
The factory wheel does have an adapter, or "mounting hub". If you can't find one, there are some uplevel late 80's-early 90's S-10's that use the same mounting hub.
Old May 22, 2010 | 09:22 AM
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
anyone that has ever put a chain steering wheel on any car should be beaten with a bat. good job removing that offense to good taste from your car.
Old May 25, 2010 | 10:02 PM
terl30's Avatar
i have looked all over ebay for 82-92 camaro steering wheel hub and for s10 and all i can find is for aftermarket steering wheels. any ideas from anyone on where to take this search would be appreciated. thanks
Old May 26, 2010 | 07:33 PM
Engine: that I like
Junkyard is your best bet. I think I have a mounting hub though, on an S10 wheel.
Old Jun 4, 2010 | 01:06 PM
85 Z28's Avatar
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
SAME HERE ALSO A FELLOW 85 Z28 OWNER YOU ID THE RIGHT THING
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IroczFan
Oct 6, 2015 10:13 AM
dhonda200
Aug 11, 2015 11:50 PM
