help please putting steering column in
Car: 89 chevy camaro rs
hi i have a 1990 casmaro rs and i need to put a new steering column,but i dont know if my 88 column will fit?and i could use a quick walkthrew on what exactly im doing,cause ive never taken one off or done anything with them,and as far as re wiring them i have no clue
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: help please putting steering column in
I never had one out myself - but I can tell you you'll need to either bypass your VATS in the car, or use your ignition key switch, ignition switch, and wiring from the 1990 column as your 1990 has VATS and I don't think the 1988 does. What's wrong with the 1990 column?
evilstuie
Feb 28, 2016 03:33 PM
