Ashtray door spring
Old Jul 13, 2010 | 11:14 PM
62Rampsidekid's Avatar
Ashtray door spring
Does anyone have a picture of the ashtray door spring? I took the center console top off to see why the ashtray door would not stay closed and found out that the spring, I assume it is a spring since there is a small hole in the door lever and a small hole in the console top, is missing. This is a new to me car so no telling how long it has been this way. I would like to replace the spring but don't know if it is a spring wire or a regular spring. Anyone have any pics or a good diagram that shows these parts?
Thanks!
Old Jul 13, 2010 | 11:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Ashtray door spring
What year and type of car are you referring to? That would help out a lot
Old Jul 14, 2010 | 12:02 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's actually just a wire about the size of a jumbo paperclip - it's spring steel. Lok under there (run a magnet around) and see if you can find it - otherwise search classifieds here or ebay.
Old Jul 15, 2010 | 06:25 AM
Sorry, car is an 88 RS V6 with a/t.
I will be taking the cover off again today since my new shifter slider broke again, the plastic piece I found does flex quite enough to keep it attached like the stock piece. I try something different with the shifter but will look around with a magnet and flashlight for that wire spring, thanks!!
Old Jul 15, 2010 | 01:02 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I have a bunch of them around here if you need one
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
