Where did you put your shift light??
Old Jul 15, 2010 | 02:56 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Just wondering where everyone put a shift light in there car as Im thinkin of putting might where the cigerette lighter is as mine doesnt work anyways. If you have pics of what you have done that would be awsome. Sorry if there has been a post of this before but i couldnt find one. Thanks
Old Jul 15, 2010 | 04:14 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Where did you put your shift light??
I actually have two... long story. I like both locations.
One is where the cig lighter is, the other is beside my tach. The cig lighter one was first, but the tach I have came with its own integrated shift light - I cant find a way to extend it all the way over to the cig lighter either. Oh well.
Old Jul 15, 2010 | 05:12 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
My shift light is mounted on the steering column using a big hose clamp.
Old Jul 15, 2010 | 11:22 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
I had mine mounted under dash between gauge cluster and AC Vents till I bought my new tach its mounted under the ac vents between the radio and ac vents with light attached to tach
Old Jul 15, 2010 | 01:08 PM
6SIX6's Avatar
Car: 89 IROC
Could i get a pic of what it looks like in the dash and did you have to cut the dash behind the lighter to make it fit??? I assume you used an autometer one.
Old Jul 27, 2010 | 01:50 PM
6SIX6's Avatar
Car: 89 IROC
lookng at getting one of these and replacing the cigerette lighter with it.
http://www.summitracing.com/parts/ATM-3387/
Anyone done this yet at all as Im lookig for pros and cons to it. I really like it as it will fit in the spot with minimal cutting and has the modual built into it instead of buying 2 pieces to make the shift light work. Any help and info on them would be awsome. Thanks
Old Jul 30, 2010 | 03:57 AM
6SIX6's Avatar
Car: 89 IROC
Picked this up the other day just wondering what people think???
Old Jul 30, 2010 | 06:36 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Harlan shift lift FTW!
Tucked descretely under the dash pad by the headlight switch.
Bright enough to get your attention, but not bright enough to blind you. Fully programmable in 100rpm incriments.
J.
Old Jul 30, 2010 | 11:20 AM
6SIX6's Avatar
Car: 89 IROC
J.
Thats pretty cool man I like it. Im gonna try where mine is going to go and if its too bright ill move it. Supposidly itis adjustable so i can adjst the brightness
Old Aug 23, 2010 | 11:42 AM
6SIX6's Avatar
Car: 89 IROC
Well I finally got around to putting my shift light in and I went with a stewart warner rpm / shift light. Just wondering what everyone thinks?? I like it and i know a few people I know didnt care for it
Old Aug 24, 2010 | 11:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's not my cup of tea, but if you like it, that's all that matters.
When I do mine, I'm hoping to get one that's small enough to mount down inside the cig lighter hole so that when I'm not at the track I can re-install the lighter to hide it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
