So how does this damm interior dome lamp secure on?
Old Jul 20, 2010 | 08:46 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I have found the missing dome or interior headlamp and can not figure out how it secures. I do not have the cover but just the actual black peice or base as I would call it. How does it secure? Are there special nuts that are put over the 2 studs?
Thanks.
Old Jul 20, 2010 | 09:26 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: So how does this damm interior dome lamp secure on?
You need two tiny speed nut, like these :
In my T/A someone used small zip ties and cut the excess, it held very well.
Old Jul 20, 2010 | 12:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can get a pack of various sized speed nuts at any auto parts store in the HELP! section for about $3 - there will be the right size in there.
Old Jul 20, 2010 | 12:21 PM
Carlos773's Avatar
http://www.autozone.com/autozone/acc...er=517650_0_0_
Would those be it? Part #45382
Old Jul 20, 2010 | 12:36 PM
Car: 1992 RS
Engine: Carbed 350
Nope - not the same thing. Those are more like the things that hold the screws in the shifter plate, radio bezel, etc.
This is it: http://www.autozone.com/autozone/acc...mString=search
They are called push nuts
Old Jul 20, 2010 | 12:51 PM
Carlos773's Avatar
I Love you. I found the whole lamp assembly in my crap bin. Saved myself a yard trip. I am going to go pick them up now, Damm headliner is sagging from not having the lamp on.
Old Jul 20, 2010 | 01:47 PM
Car: 1992 RS
Engine: Carbed 350
I'll take that as a manly "I Love You", ok?
Save that link to the Dorman site - it's a great resource! Not always will the parts stores have everything, but everything is catalogged on their main page - they sell thousands of products like that, little obscure things. And if you find it in the catalog online, then Autozone (or others) can order it for you by product number.
Old Jul 20, 2010 | 01:50 PM
Carlos773's Avatar
You have no idea, I was gonna make a 50 min yard trip to just get another lamp with mounting hardware.
Old Jul 21, 2010 | 11:36 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Why bother spending $10 bucks...............
If the stud part is still left in the ceiling holes just take a pair of vice grips
and turn them back and forth and pull them out.
Then scrounge up 2 small self tapping screws or similar and mount your dome
lamp base. I just did this when I replaced my missing dome light.
Old Jul 21, 2010 | 03:27 PM
Carlos773's Avatar
Well the packet from autozone was a dud. It had 2 pairs which looked like they might fit but it would only go about 1cm in
I will try it Jaab, I think I have a few extra tapping screws around her.e
Old Jul 29, 2010 | 03:44 PM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
How do I take those off?
My parts car dome light shadered when i went to turn them.
Old Jul 29, 2010 | 04:47 PM
Car: 1992 RS
Engine: Carbed 350
You have to be gentle - the plastic housing becomes very brittle after years of getting 'cooked' by the light (another reason to swap to LED). Pry gently on the sides with a tiny (glasses repair) screwdriver, then get a pair of needle nose pliers on it and gently wiggle it off.
Old Jul 29, 2010 | 11:11 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Like I said...............Grab hold of the exposed stud with vice grips and turn
back and forth and down. The stud and speed nut will come right out.
Prying on the speed nut will only break the plastic and the metal stud !
ASK me how I know !..............
Use 2 new self tapping screws to re-install the base.
Old Jul 31, 2010 | 05:09 PM
Car: 87 formula
Engine: LG4
Worked easly just pulling the studs out.
Hey is there a direct plug in led bulb?
Old Aug 1, 2010 | 11:47 AM
Car: 1992 RS
Engine: Carbed 350
I'm sure there is - seems to be one for everything these days.
But I wanted brighter interior lights! I ordered a 30 LED array from ebay - it's a square board that just fits inside the dome housing. I just cut the wires from the OEM light clips and connected to this - now I can actually see inside the car at night!
Old Aug 1, 2010 | 11:57 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
If you need another lamp housing I have 2 in good shape sitting in my garage. Where are you in Chicago?
Old Aug 14, 2010 | 11:19 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
I tried pulling on the metal stud using some vice grips but it won't budge. I'm leaving metal markings on the studs from the grips. I'd say I'm applying a substantial amount of force (wiggling/pulling down). Any idea why these won't come off?
Attached Thumbnails So how does this damm interior dome lamp secure on?-2010-08-14-15.14.00.jpg
Old Aug 14, 2010 | 11:56 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Those studs should of pulled right out pretty easily..................
How about prying off the speed clips then?
Hmmmm............
Old Aug 16, 2010 | 07:56 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I dont think they are supposed to "pull" out. I used small vise grips to unscrew them like a threaded stud. All the ones ive done come out easily that way. i have 2 in mint condition w/ studs. pm me if anyone wants one.
Old Aug 16, 2010 | 09:01 PM
gta90's Avatar
Thanks. I'll try unscrewing them.
Old Aug 17, 2010 | 09:43 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
READ my FIRST 2 posts...................
"TURN stud back and forth while pulling down"
Sorry I forgot to be LITERAL in my 3rd post!
junior419
Apr 7, 2025 11:35 AM
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
