Dash vibrating?
Old Aug 3, 2010 | 11:07 PM
lionsfb57's Avatar
Car: 87 iroc z
Dash vibrating?
hey guys, when my car gets up to around 70 my dash starts vibrating pretty bad, anything i can tighten or re adjust to fix that?
Old Aug 3, 2010 | 11:21 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Dash vibrating?
Check your tires for wear or busted radials, tire air pressure and correct wheel balancing. Everytime over the last 15 years when I had that problem one of the three was the cause.
Old Aug 3, 2010 | 11:22 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Dash vibrating?
Mine doesnt do that but everytime I hit a bump in the road the dashboard just bounces all over the place. So yeah what can we do to fix this?
Old Aug 3, 2010 | 11:25 PM
Axle/Gears: Posi
Re: Dash vibrating?
Originally Posted by '87IROCZOWNER69
Same thing happens to mine but it also bounces all over the place everytime I hit a bump in the road. So yeah what can we do to fix this?
Tires. I bet my lunch you need to start there. It is amazing what a new set will do for the handling of our cars. My 92 was doing that in the spring. I got a new set of tires and viola, I could let go of my wheel and for at least a mile my car will run true with no shake of the dash or drifting.
Old Aug 3, 2010 | 11:37 PM
Re: Dash vibrating?
I just put brand new tires on a few months ago, they only have 2,000 miles on them.
Old Aug 5, 2010 | 09:08 AM
Axle/Gears: Posi
Re: Dash vibrating?
Double check your wheel balancing. Also check for a busted strut.
Old Aug 5, 2010 | 10:53 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dash vibrating?
Do you have all the screws in place? Are they stripped?
There are 4 screws in the top - they are in the defroster vents, 2 in each vent. And then there's 6-8 screws under the dash lip, all the way across the front. They all take 7mm socket.
For the OP, I agree with 86niterider - sounds like a balancing issue - make sure you get spin balanced and not bubble balanced.
Old Aug 5, 2010 | 12:12 PM
Re: Dash vibrating?
Im missing one screw from the vents and 2 others were forced straight through the plastic by PO. There are about half or more of the ones underneath missing. What size are the screws that go in each spot and where could I get more? I would like to get screws with a wider top on them for the ones in the vent because the holes look wider from where some were forced through.
Old Aug 5, 2010 | 08:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dash vibrating?
JY has tons of them, otherwise take out one, careful to not drop one down a vent, and take it to the store with you. Might try small washers, size depends on how big the holes are now
Old Aug 5, 2010 | 10:17 PM
Re: Dash vibrating?
Whose JY? Is JY kind of like a ACE Hardware?
Old Aug 5, 2010 | 11:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dash vibrating?
Junk Yard. Probably easier to take one that's still attached to your dash to your parts store
Old Aug 6, 2010 | 12:15 AM
Re: Dash vibrating?
Thats what I was thinking. There is a you pull it about 4 miles away but I heard they have bad service either way I have always wanted to see what they got.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
