Lower shift boot ANYONE??
Car: 91 camaro
Engine: LS3
i need the lower shift boot plate i cant find it anywhere everyone stopped selling them there has to be an alternate or someone out there?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Lower shift boot ANYONE??
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Where the hell was this info 2 months ago when I was looking for one? Has anyone actually ordered this to prove it is the correct one? I have looked at the actual parts fiche for the 3rdgens and have never come across this part number anywhere; all the #s listed for the lower boot on the fiches show discontinued.
Car: '84 Berlinetta, '86 Z28
Engine: 2bbc 2.8, MPTI 5.0
Transmission: 5spd manual, 4 spd auto
I am currently on this same task myself. I ended up having a shrew jump out of the console/vent. During the tear down to check the wires I found that the previous owner "cut" out around the boot. Now that I'm looking I'm having the same problem as you guys. From what it appears the options would be either construct one or get one from a "you-pull" salvage.
Axle/Gears: 3.23:1
Car: 89 Iroc Convertible
I have one from a 4th gen available for sale if interested
Car: 1989 Trans Am GTA
Transmission: M28 T56
I am not sure who owns the copyright. I purchased them from ebay for $5.99 each. I can tell they are hi-res scans of GM originals, but I dont know who did it.
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Call me crazy, but I just used a universal boot from autozone for 14.99. It is close in size to the original. I didnt have an original, but I assume it is a little larger. It had thick rubber like an original (I saw a poor condition one in the junk yard) and came with screws. It is all going to be under the shift plate anyways so you will never see it.
Car: 1991 z28 vert/91 rs vert/85 TA vert
Engine: stock tpi 305/tbi 305/tpi 305
Transmission: 700r4/ 5 speed
Axle/Gears: 4th gen rear in progress/stock
I have one from an 88 iroc, OEM. In great shape... make me an offer if you still looking for one.... thanks Ivan
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I just found another OEM one as well. Great shape. LMK if you need one or any further information
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
