What does this little switch inside the steering column do?
Old Oct 15, 2010 | 03:54 PM
zgt's Avatar
zgt
Car: '89 z28 305 stock
While I was reassembling my steering column I was unable to get this thing back in with it's little spring, so I just left the spring out and pushed the switch in alone. Anyone know how important that little spring is and what it does?
Old Oct 15, 2010 | 05:37 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Re: What does this little switch inside the steering column do?
key in the ignition buzzer I think - been a few years since I was inside mine, but IIRC, it was the buzzer.
Old Oct 15, 2010 | 07:41 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If by spring your talking about that little piece under it.That keeps the "switch" inplace by pushing it upwards.So when the key is inserted.It pushes down on center portion & the two brass contacts within the plastic body touch.This completes the circuit & the buzz is initiated.
Easiest way to install it.Is to compress the spring While pushing it in.There is a small green plastic button on the bottom of the lock cylinder.This is the part that pushes on the switch.If you had the key in the ignition before trying to install the buzzer switch.The key would hold the green button & make it very hard to install th switch.
Either remove they key or put the ignition in "run" position, cant remember.I think there is a screw that holds it inplace, cant remember either.
Old Oct 17, 2010 | 02:09 AM
zgt's Avatar
zgt
Thanks, I'll try again when I get back into the steering wheel. The buzz is actually working fine without the spring tho =o
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
