aftermarket gauges
Old Nov 14, 2010 | 07:51 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
aftermarket gauges
i pick up a 92 camaro rs and i intall a carb 355 in it and now i need gauges so i look on summit and i found the VDO guages #600905 and i want to know if they will work with my set up? i have no gauges at all right now thanks
Old Nov 15, 2010 | 09:26 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: aftermarket gauges
No this will not be a direct replacement
Your Speedo is Electric, The VDO one is Manual
Your Water Temp is PROBABLY Manual, the VDO is Electronic
You Fuel Gauge is 0-90 Ohms, The VDO one is 10-180 Ohms
I'm sure you could make the modifications to use that set, but it would likely cost you the money you were trying to save by using it. I'm using iEquus Gauges in my Camaro. You can get them at O'reilly's and they look good. I'm using the 8000 Series. I think i paid around $200 for a full set.
Old Nov 15, 2010 | 10:07 PM
Engine: 355
you have any pics and i look and i looks like they sell single the gauges
Old Nov 17, 2010 | 07:48 AM
383 Power's Avatar
Here's a link where i was showing off my Installation. The picture isn't great, but the gauges have a brushed aluminum look in the front. They're the iEquus 8000 Series. There are also the 6000 and the 7000 series that you can get. Overall, i'm pleased
The Link:
https://www.thirdgen.org/forums/inte...tallation.html
Old Nov 17, 2010 | 07:51 AM
383 Power's Avatar
If i remember when i get home, i'll try to take another shot and post it, but i'm pretty forgetfull.
Old Nov 17, 2010 | 08:40 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What's wrong with the gauges the car came with?
Old Nov 17, 2010 | 09:31 AM
383 Power's Avatar
What's wrong with the hood that the car came with?
What's wrong with the Wheels the car came with?
What's wrong with the Interior color the car came with?
What's wrong with the Original Color the car came with?
What's wrong with the Engine the car came with?
What's wrong with the Tire Size the car came with?
What's wrong with the Shifter **** the car came with?
What's wrong with the Rear End the Car Came with?
What's wrong with the Dash the car came with?
My Point? If you're trying to restore a car, you look for OEM parts and try to make it look the way it was when it was new. If you're trying to make the car your own, you change things. How many people do you know that move into a house and keep it the same way? When you get your desk at work, do you just put paperwork on it, or do you have decorations and pictures of Family and Friends? Why do people bother to add things like Subframe connectors and upgrade their suspension? None of that stuff was originally needed, right? If everyone wanted to restore their car to original, this would be a pretty boring forum. Everyone would be talking about the SAME EXACT THING. In my case, i had the gauges with the double sided needles. I hated those. What's wrong with a little originality?
If you just meant that you could help him fix what he had and save some expense, i'm sorry i jumped on you.
Old Nov 17, 2010 | 09:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There was no indication given of "making it his own". He said he put in a carb, and now he needs gauges, which suggests that he's under the mistaken impression that his gauges won't work with a carb.
Old Nov 17, 2010 | 09:54 AM
mightymaro94's Avatar
i agree it seems he feels he must change the gauges... but if he just wants to then hey go for it
Old Nov 17, 2010 | 10:28 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I think I see where the " What's wrong..." question came from.
1986chevycamaro-- when you say "...no gauges at all ", do you mean--NO GAUGES, as in they don't work?
Or the gauges have been taken out?
383 Power---
Thanks for the pics!! Never new Equus made gauges, & they look good!!
Old Nov 17, 2010 | 11:33 AM
383 Power's Avatar
Thanks. So far so good on em. I got all the kinks worked out but the Fuel gauge and i'm convinced that it's the sender. The Gauges all turn red at night too.
Old Nov 17, 2010 | 12:30 PM
Engine: 355
i have no wires for the gauges at al guy cut the wires out so i need everuthing new
Old Nov 17, 2010 | 12:53 PM
Engine: 355
well i just try getting the gauges from O'reilly's and they dont have the 8000 series or anything as a set you have to buy singles? wonder if they got rid of the sets?
Old Nov 17, 2010 | 01:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
So you have no gauges at all? Or they're still there but all the wires are gone? Are the senders still on the engine? Do you want aftermarket gauges for appearance, or do you just want the quickest way to have functional gauges again?
Old Nov 17, 2010 | 01:51 PM
383 Power's Avatar
you can buy Oil Pressure, Water Temperature, and Volts as a Set.
Old Nov 17, 2010 | 04:36 PM
Engine: 355
car was a v6 guy started to take everything out to make it a race car so i put my 355 carb so there is no send units no wires and no gauges at all no even stock i have just cluster with out gauges
69GTOby
Apr 18, 2016 02:34 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
codeysabatini
Sep 20, 2015 11:36 AM
