Question about forth gen seats
Old Nov 15, 2010 | 05:48 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
I found today at a local junkyard 2 4th gen seats, there a little worn and there is some rust on the seat tracks which I know is common my question is since the 4th gen seats are a direct bolt into 3rd gen cars can I simply take the tracks off my 3rd gen seats and put them on the new forth gen seats. Also I plan on recovering these seats my self but I am having trouble finding a company that makes re upholstery kits for just the two front 4th gen seats, anyone know any info on these issues I would be very appreciative of it.
Old Nov 15, 2010 | 06:05 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Question about forth gen seats
the rust is common, but i would POR15 the seat tracks before putting them in, it would look a hell of a lot nicer... i also heard that the 3rd gen seat tracks are way lighter than the 4th gen ones, so I would like to know this as well!
Old Nov 16, 2010 | 07:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
PM me for info on front seat covers. Just keep in mind that the aftermarket seat covers aren't the same fabric as the originals, so if you only recover the fronts, they won't match the rear.
Old Nov 16, 2010 | 08:00 PM
Engine: 383 stroker
so does anybody know about the tracks
Old Nov 16, 2010 | 10:07 PM
Stephen's Avatar
Car: 87 GTA
The 3rd gen seat track should be taller. I suppose that would be good for the short guys.
Old Nov 16, 2010 | 10:26 PM
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
Really? i think i need to swap in some 4th gen seats then. im 6'4 and need every last bit of head clearance i can get.
Old Nov 16, 2010 | 10:49 PM
Stephen's Avatar
Car: 87 GTA
Yep. I'm 6'5" and plenty of headroom to spare (4th gen seats).
Old Nov 17, 2010 | 12:44 AM
Engine: 383 stroker
OK well I found out that my stock tracks will work with the 4th gen seats....My new question is does anybody know which bolts connect the tracks to the seat itself?
Old Nov 17, 2010 | 12:52 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
there are 4 bolts u gatta move the tracks around a lil bit to be able to get to them but shouldnt be a problem just watch ur fingers the springs are pretty tuff and with out any weight on them they will shoot foward when u hit the lever to move the tracks.. i got the stitches scares to prove it and i knew about it.. just had my hand in the wrong place
Old Nov 17, 2010 | 04:04 PM
Engine: 383 stroker
Ok well I took the tracks off the passenger side seat today not really that hard started to sand down the rust..... but when I got them off I realized that the seat pan has rust on it so I took off the seat cover some and bam rust, rust and more rust came off.. I know that they used low quality steel to make these parts but dang I havent seen this type of rust on interior parts before even from a junkyard parts car, well after about 2 hr grinding and sanding I got most of the rust I could reach off but to get it all off I am going to have to separate the seat pan from the back part of the seat does anybody know how to do this? Also I have heard of Por 15 but that you basically have to sand blast the metal before you use it, I have also heard of rust bullet being really good to stop rust, has anybody used it or have any other suggestion about what to do to get rid of the rust.
Old Nov 17, 2010 | 06:56 PM
POR15 does not need to be sanded down to use.. It actually paints over rust and after that it will never rust again.. There is prep tho.. You need to degrease it, then use 'metal ready' (spray it on with a bottle) and then paint it on with a brush or spray (in this case, i think brushing it on is the easiest way to do it if you can't remove it from the seat completely.)
I painted the whole underbody of my car here with POR15 and it came out pretty good:
https://www.thirdgen.org/forums/body...ml#post4668217
Old Nov 17, 2010 | 09:18 PM
Engine: 383 stroker
thanks
Old Nov 18, 2010 | 10:28 AM
To be clearer, you CAN sand the rust down and still paint over it, but you still have to prep it. So it is up to you. Some people say it adheres to rust better than smooth metal but in my experience it has work on both. They say it's all in the prep..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
