window motors
Old Dec 30, 2010 | 07:09 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
window motors
need some help here changing my windows motor and i am kinda stuck
so i am guess i need to raise the window at this point but i got the old motor out and soem spring popped out during removal i need a guid to reinstall the new motor and the spring this is starting to frustrate me
Old Dec 30, 2010 | 07:19 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: window motors
Remove the whole regulator and install the new motor in it, out of the door then reinstall.
Old Dec 30, 2010 | 07:29 PM
Re: window motors
didnt see how i would be able to get the regulator out of the door lol was afraid to bend something
Old Dec 30, 2010 | 08:10 PM
J91's Avatar
J91
Re: window motors
Unbolt it from the window and door, it'll come out, just finesse it!
Old Jan 1, 2011 | 06:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: window motors
If the spring came out, you may need to undo the 4 rivets holding the regulator to the door and remove it from the window track, which means you will need to remove all of the other window tracks first (and the 2 fuzzies at the top of the door sills), so mark the positions of the adjustment bolts.
Oh, and do be careful. That spring in the middle of the regulator is a killer. I have a 1/2" scar on my hand from that SOB.
Old Jan 1, 2011 | 06:55 PM
Re: window motors
i am so frustrated i think i started someting that i actually cannot finish and i cant move forward on the body work untill i finish the ****ing window
Old Jan 1, 2011 | 07:01 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: window motors
You're better off having the glass inside the door. Either that or completely out (both of mine are out). Especially if you need to replace the outer window sweeps. I'm going to assume that the window is pretty much sitting at the complete bottom of its travel inside the door. All you need to do is remove the 2 bolts on each track (2 bolts and 2 nuts on the front triangle track) and slide the tracks off of the wheels and out the openings in the door. Which is easier with the window up, but it can be done.
Old Jan 1, 2011 | 07:07 PM
Drew's Avatar
Re: window motors
Changing window motors is a 20 minute job if you just drill a couple of 1/2" holes in the inner door to access the rivets that are covered. Then you can just drill and replace the rivets through the holes.
Now that you've got the thing screwed up, you're pretty much stuck working on the regulator inside the door, or removing the regulator. I don't envy you.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
