what causes this?
Old Jan 27, 2011 | 07:10 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
what causes this?
ok so i bought my 88 in nov. everytime i start it the dash shakes and seems to wave at me. ( i dont mind, kinda like her saying hi to me lol)
stops when idling
any ideas on how u fix this?
Old Jan 27, 2011 | 07:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: what causes this?
put the screws back in that hold the dash pad to the dash face, they are (or supposed to be) right under the lip of the pad, just above the guages, and running across the entire dash. maybe 8-10 screws?
Old Jan 27, 2011 | 07:19 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok ill check that out when i feel like shoveling a path to the garage lol
thanks
Old Jan 27, 2011 | 07:22 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
bummer..its 72 here
should just be the screws
Old Jan 27, 2011 | 07:25 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ill trade climates with u mikey
Old Jan 27, 2011 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i had a foot of snow to deal with this morning, 4' at the end of the driveway....
Old Jan 27, 2011 | 07:33 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
same man, but atleast it wasnt super heavy, wet snow. it wasnt as bad as i thought it was going to be, last night it was just horrible outside with all the wind
Old Jan 27, 2011 | 09:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Suppose to be in the 80s friday here in So cal.
Check the 10mm nuts at each end of the dash.
Old Jan 27, 2011 | 10:42 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
The begining of the week it was nice but now its going down to the mid upper 50's here in Northern California
If your dash screws check out (there should also be two in each defrost vent opening) check your motor and tranny mounts. Those V6's are kinda harsh when turning over.
Old Jan 27, 2011 | 11:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Ugh... Take the dash pad off and tighten the 5 bolts holding the dash housing to the cowl lip underneath it (one on each side of each dash speaker and one in the middle), and then the 10mm bolt at the bottom of the metal center support bar in the middle and also the 10mm bolts at the sides. THEN tighten the dash pad.
