Interior Tear Down
Old Jan 28, 2011 | 01:28 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
Interior Tear Down
so i started tearing apart the interior of the car, the dash and all of that. do i have to take the centre console off in order to take out the dash? i seem to be having problems, like something in the middle is holding still but theres no screws left lol. aswell im seeing alot of electrical tape.. not good, looks like alot of **** is mcgyver'ed together and not done properly.. gonna be asking you guys for some help when i get pics, its not lookin too good. hahahha! i wanna rebuild this car from scratch.
Old Jan 28, 2011 | 02:04 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Interior Tear Down
Yes I'm pretty sure the console will have to come out. Shifter **** will have something like a big staple in the front side of it. You'll have to dig that out of the **** to remove it.
Old Jan 28, 2011 | 02:08 PM
BrandonSB's Avatar
Engine: 30Slow
damn.. lol alright ill have to get it out then. and thanks for a reply!
Old Jan 28, 2011 | 02:10 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
No problem and good luck.
Old Jan 28, 2011 | 02:14 PM
BrandonSB's Avatar
Engine: 30Slow
thanks ill need it.
Old Jan 29, 2011 | 11:36 AM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
ineresting. i got a 1986 camaro, and i took the dash off fine. just the screws underneath it. never had any problem with the center console. wait are you talking about the dash pad or the whole dash itself?
Old Jan 29, 2011 | 04:34 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
There is a hidden screw you will have to look and make sure you remove the emerg. brake handle (careful of the small screw) and pull the handle all the up and turn the console as you remove.
Small screwdriver works best.
Have a look at my build thread in my sig. I replaced my entire interior with NOS pieces. Some of the pics should help you. Feel free to PM if you need more help.
Old Apr 17, 2011 | 12:16 AM
DoWork2day's Avatar
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
Removal of the rear seat backs are giving me trouble. I appreciate the tip on taking the shifter **** off, I was trying to push that staple IN and not dig it out. So thanks!
The rear seat has a torq bit, which I do have, but there's no room to get the ratchet on the torq bit.... what tool do you use to get that rear seat backs removed?
Old Apr 17, 2011 | 12:29 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I just had those removed, very hard to get unscrewed. But they do come off.lol
Old Apr 17, 2011 | 01:59 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Rear seat backs are removed by taking out the 13 mm swivel bolts on the bottom. Top torx bolts stay in, just pull lever to disengage the seat(or seats) from those pins
Old Apr 17, 2011 | 03:46 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Just a tip on the rear seatback... much easier to see and get at if you remove the bottom part of the rear seats first.
Old Apr 17, 2011 | 05:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Right. and they each have only one 13mm bolt in the front of each one
Old Apr 17, 2011 | 11:35 PM
DoWork2day's Avatar
Yeah thanks, I did find that all I had to do was remove the nut instead of that torx bit.
Guess what else, as I'm swapping the interior from the RS to this Iroc, there is NO PINS to hook the rear seat backs to! I could bolt the seat backs in, but there's nothing to hinge them on over the hump. Maybe someone figured they would have more room for the passengers if they just removed the seat backs and left the bottoms in? Then they removed the pins?
Or was there a change in the way they mounted the seat backs? I doubt it. Also, get this..........
................... There are some kind of boxes, or maybe they are relays under the center console. It's a wired box, with what looks like glue holding the internals together. The RS I have has these boxes screwed to mounts, but just like the rear seat back pins, the mounts for these relay/boxes things don't have anything there to screw them to! This car is weird. But it's a monster so I'll drive it for awhile, buy some bolt ons and probably put everything in another thirdgen someday.
Old Apr 19, 2011 | 04:53 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
For the rear seat backs there are two styles a solid one piece back that folds down or the split rear back that each half folds down. The split rear seat uses a bracket that is spot welded to the trans/drive shaft tunnel as the inside mounting hinge point. These can sometimes be found on ebay and members here have been known to take the time to get them off and sell them.
Old Apr 22, 2011 | 12:29 AM
DoWork2day's Avatar
Thanks Phoenix I was wondering why I didn't see any marks from spot welds. I have another RS car in the yard that has the pins welded to the trans tunnel. There's different seats you say.... I actually like the idea of just having the seat bottoms and they have more room back there IF I have that many passengers. They could use the seat belts too as well.
Old Apr 22, 2011 | 09:21 AM
91phoenix's Avatar
I would be wondering how comfortable that would be without a seat back but you can try sitting in there yourself and see. Do a search on ebay for seats 82 Camaro and also 93 Camaro. One of the listings will show the one piece back seat.
I have the one piece back seat in my Firebird but am going to weld in the pin hinge bracket for the split back seat. I got the whole bracket and nuts for the seat backs at the hinge side and other parts for $5 on ebay. No other bidders.
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
m00n420
Sep 11, 2015 02:39 PM
