Could temperature gauge literally be stuck?
Old Feb 9, 2011 | 10:18 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hey,
I daily drive my IROC and the temperature gauge has ALWAYS worked perfectly. However, 2 days ago the needle went ALL the way up to the top, and looks almost like it's stuck up there. It never moves (when the car starts, or engine shuts off).
Has this happened to anyone? Could the gauge possibly be stuck? Do I just pop off the gauge cluster and unstuck it?
Old Feb 9, 2011 | 01:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Could temperature gauge literally be stuck?
Have you checked the sender wire? Its green, driver side head, between #1 & #3 spark plug. If its not getting a signal (come loose, come off, or break in the wire) then the guage will peg out.
Old Feb 9, 2011 | 01:54 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Yes, tap the dashboard and see if it comes unstuck. Thats what I used to do on one of my cars. If it works and does it again simply remove the front cover and push the end of the needle down some(towards the gauge face) to keep it away from the gauge panel when it sweeps upward. If that doesn't work you may have a short like stated above.
Old Feb 9, 2011 | 05:05 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Thanks !
I'll try it out sometime soon and let you know. Unfortunately it's like -20 right now so I don't want to freeze my *** off in the garage
Old Feb 9, 2011 | 05:08 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
I had this issue with my 87 IROC. It would stick the needle during startup for some reason; I tried replacing the sender and pushing the needle back to no avail. Ended up trimming the tip of the gauge needle off and it works to this day for its current owner.
Old Feb 10, 2011 | 07:46 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
My t/a was like that when I bought it, ended up being a bad gauge. If you move the needle, and it goes without any resistance, and will keep spinning if you were to flick it (Don't just flick it, don't want to break it if it does work) than its probably a bad gauge.
Old Feb 10, 2011 | 10:42 PM
thewizard's Avatar
I agree that's likely the problem; pretty simple circuit.
Old Feb 12, 2011 | 08:42 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Perfect find. My temp gauge did this today for the first time. Have to check all things mentioned before I begin to replace things.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Logan Bryant
Sep 23, 2015 06:51 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
corey8084
Sep 17, 2015 02:56 PM
