gauges wont work
Old Feb 27, 2011 | 07:46 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
gauges wont work
SO i just put new layouts behind my gauges and now my gauges wont move. i set them all to 0 before i took the needles off and but them back on the way i took them off. any ideas on how to reset these? my rpm or speedo wont register either...HELP pls
Old Feb 27, 2011 | 09:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: gauges wont work
Too thick to let the needles move...
Wrinkles...
Needles not engauged correctly ( pressed too tight, not tight enough )
Not a big fan for this reason, but that's my
Good luck
Old Feb 27, 2011 | 11:06 PM
avilla20's Avatar
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
Old Feb 27, 2011 | 11:09 PM
clean92rs's Avatar
Car: 92 camaro RS
the needles are on good but they are not touching the layouts
Old Feb 27, 2011 | 11:10 PM
avilla20's Avatar
did you connect the cluster?
Old Feb 27, 2011 | 11:31 PM
clean92rs's Avatar
Car: 92 camaro RS
yes. the light and everything come on. the connectors are clipped into the dash so when you set the cluster in place it connects its self.
Old Mar 1, 2011 | 03:10 PM
clean92rs's Avatar
Car: 92 camaro RS
bump any ideas
Old Mar 4, 2011 | 07:56 PM
clean92rs's Avatar
Car: 92 camaro RS
any one have any ideas? im starting to get really mad at this dumb mistake i have made. i checked the gauge fuse and it is still good and the cluster connects to the plugs when it sets in place. HELP please!
Old Mar 19, 2011 | 01:00 AM
clean92rs's Avatar
Car: 92 camaro RS
ok so i got the RPM gauge to work but the rest of the gauges are not reading. any ideas?
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
