converting to split back seats?
Old Mar 22, 2011 | 08:44 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I've been offered a set of deluxe interior seats, but before I get them, I'd like to know what's involved in converting my solid back rear seat to a split back. I did a search, but I must not have used the right terms because I didn't come up with much
Old Mar 22, 2011 | 08:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: converting to split back seats?
You'll need the spot welded on studs that slip in the holes in the seat backs, so that they can pivot on them.
Old Mar 22, 2011 | 08:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its actually a single bar, welds to the top of the tunnel with a reinforcement olate over the top to spread the load. IIRC, its something like 1/2" OD.
cutting it form a doner car wold be the best route, you can get some basic measurements at the same time
Old Mar 22, 2011 | 08:50 PM
58mark's Avatar
do I need a special factory bracket, or is it something that can be fabricated with relative ease? I have a car available that I can take measurements from
Old Mar 22, 2011 | 08:58 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
i drilled the four spot welds and pulled the bracket with a flat head screw driver. When I go to drop mine back in, again...4 spot welds and i'm done. Of course I would set the back seats in there so that I can get proper alignment while spot welding or even mark the spots to weld, but I have faith in my welding to not screw up my seats lol.
Old Mar 22, 2011 | 09:27 PM
Car: GTA
Well yeah. 1 big flat bar like a saddle on the tranny tunnel, with the 2 studs sticking out of it.
When you cut one out of a junkyard, I'd take every measurement you can think of to locate them, and then take some more. Not sure how you could set it in there with the seat backs & then mark its location with everything in there.
Old Mar 22, 2011 | 09:30 PM
58mark's Avatar
Dont guess anybody has close pics of what one looks like...
Old Mar 23, 2011 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
here, the 2rd post has a pretty good picture
https://www.thirdgen.org/forums/memb...ml#post4865578
Old Mar 23, 2011 | 09:17 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
If need be I have a Camaro with split seats and one with one piece I can take pics or whatever is needed
Old Mar 23, 2011 | 09:36 PM
58mark's Avatar
yes, that does help. I'll still go to my buddies car for exact measurements, but at least I can picture what I need
I'm having another thought though... I might need to buy a new set of fabric covers for the seats when I get them. I could always buy the set for a solid back set, and just reuse my one piece back, but with the delux covers... right?
Old Mar 23, 2011 | 09:51 PM
Car: 91 RS T-top
I do believe so. Sorry wont be home until 11 so ill take pics then unless I'm beaten to it
Old Aug 5, 2021 | 10:04 PM
Brian Laycox's Avatar
Couldnt someone drill holes into the bracket and bolt it down? I just got a set of split seats so I was looking at theses old posts. First id need that bracket with the studs pin. Then who does the spot welding? I might just glue in a metal rod between the two halves and make it solid and non-split. Not like I'm gonna be throwing anything viable into that useless trunk! lol
1992 Trans Am
May 10, 2023 07:19 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
