who has the best carpet
Old Apr 9, 2011 | 07:49 AM
bigirish67's Avatar
Car: 1987 Iroc z/28 med Maui blue
Engine: 305 carb
Placing a order today who has the best carpet for a 87 iroc?
Old Apr 10, 2011 | 05:36 PM
bigirish67's Avatar
Engine: 305 carb
Re: who has the best carpet
Anyone
Old Apr 10, 2011 | 10:19 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I just bought some made by ACC Mats (Auto Custom Carpets) and while the color match was near perfect (grey), it is not "moulded to a factory floor pan for a perfect fit" in the sense that the stock carpet just drops in place. It also has no holes in it for anything except the shifter. The means you have to locate and cut every single hole for seat belts, seat rails, power seat wiring, rear seat mounts etc. It's a big project. Looks ok once in place, but a little lumpy. Not too happy with it for $170. Also there is a nearly impossible to cut padding underneath with various stops and starts, but almost none of them line up with anything actually on the car, which means you are stuck cutting through this impossible to cut through stuff!
Old Apr 11, 2011 | 12:10 AM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
Stockinteriors.com has gotten some good reviews...some things are a little off but for the most part sounds like they are great.
Old Apr 11, 2011 | 02:12 PM
1Aauto's Avatar
Former Sponsor
We carry the ACC ones. If your looking for a red,tan,gray etc. I can send you a free color sample too.
Old Apr 11, 2011 | 05:13 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Just fitted the ACC one, and as ZZ3Astro mentioned there's a fair bit of fettling to be done. However this one actually fits better than the moulded one I bought before, the plunging of small screwdrivers through the carpet hoping to find a bolt hole was worth it.
Old Apr 11, 2011 | 05:26 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
I got the ACC stuff from 1A Auto this week. It is true that you need to cut your own holes in most places, but honestly I think it fits/looks better after the work. I cut holes as small as possible, and I think the ACC stuff is a bit bigger, so it goes further up the floorpan in the front and back. The end result after a little more than an hour's work was quite good. Well worth the work if you ask me.
Oh... and it helps a TON if you unroll it and let it sit a day or so before trying to place it.
Old Apr 14, 2011 | 09:37 AM
1Aauto's Avatar
Former Sponsor
It's a good time of year with the warmer weather coming to do these. Yes it helps to lay it out for a day so that it reforms and warms up.
Thank you for your order,
Tony
Old Apr 14, 2011 | 03:49 PM
Hawk312's Avatar
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
U guys that have done this need to post some pics!
Old Apr 14, 2011 | 04:23 PM
campin1983's Avatar
I don't have any "in progress" pics, but here are some of the finished product. Keep in mind I have a vert done by Matrix, so the supports in the floor under the carpet aren't always the same as yours. So you do see some "bumps" you wouldn't have.
You'll have to excuse the dirty picture of the trunk. I'd laid the old piece of carpet on top of it to help make the cuts I needed, and forgot to vacuum off the padding before I snapped the photo.
Old Apr 15, 2011 | 05:24 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Ok here's a couple of the new rug fresh in, all the creases dropped out quickly though.
Attached Thumbnails who has the best carpet-photo0053.jpg   who has the best carpet-photo0057.jpg
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
