How to install the accelerator pedal?
Old Feb 1, 2010 | 11:50 AM
B'tx's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Transmission: Manual
OK, I bought an accelorater pedal with the spring but can't figure out how to install it. I have the pin that goes through the hole that connects the plastic pedal to the pedal lever (?)
Can anyone explain to to install properly and do I have all that I need?
Thanks!
Old Feb 1, 2010 | 03:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: How to install the accelerator pedal?
Thanks!
Call Toyota.
I'm just kidding. You know, in all the years I've been around cars, I've never had to R&R a late model GM pedal.
Old Feb 1, 2010 | 05:58 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Originally Posted by paulo57509
Call Toyota.
haha
Old Mar 24, 2011 | 03:37 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
I've just had the same issue, you'd think this is bloody obvious but i've been faffing about trying all sorts of combinations but I can't figure out how the blinkin spring fits in.
Willing to admit i'm an idiot if someone can shed some light on the accelerator spring install mystery
Old Mar 27, 2011 | 02:24 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The coiled part goes on the pin, to the right of the accelerator rod.The hook end goes on the accel rod, the straight end against the accelerator pedal.The pin goes in from the left side.I modified these to fit like the OEM pieces.
Old Mar 27, 2011 | 03:12 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
See attached.
File Type: pdf
Old Mar 30, 2011 | 04:03 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Many thanks guys, I think my confusion originated from the spring being set up incorrectly to start with.
I hereby declare i'm an idiot as promised.
Old Apr 14, 2011 | 10:49 PM
Louie26's Avatar
Car: 1990 RS
Engine: 305 TBI (for now..)
Thanks!
Where the bloody hell did you buy your accel pedal from?? im having the hardest time finding one! all ive found were the pedal pads or the accel rod...
Old Apr 15, 2011 | 05:27 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Modern Day Muscle supply them, they also do e-bay lots which is where I got mine from.
Old Apr 15, 2011 | 06:38 PM
Louie26's Avatar
Car: 1990 RS
aight thanks banker!
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
perZ
Aug 21, 2015 05:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
