Can I get the steering wheel off without a puller?
Old Apr 20, 2011 | 11:32 AM
tlandoe's Avatar
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
Hey guys, a friend of mine is parting out his 85 Iroc, and I have an 82 z28. My steering wheel is old and worn out but his is like mint, and I was going to take it. My question is, can you get the wheel off without a steering wheel puller?
What I mean to say is, do the little torx screws on the wheel under the horn button make the wheel come off? or is the only way to get it off by pulling the center nut? Reason I ask is I see them for sale all the time without the center part that attaches to the column.
Thanks for any help guys!
Old Apr 20, 2011 | 11:34 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Can I get the steering wheel off without a puller?
No way around removing the center nut & a puller, unless the torx screws hold it to a hub adapter, like aftermarket steering wheels, but then both cars/steering wheels would have to be using hub adapters.
Old Apr 20, 2011 | 11:48 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Autozone/Advance/Oreilly rent them for free.
Old Apr 20, 2011 | 12:22 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Sometimes you´re lucky (WD40 helps however) and you can pull and wiggle it free after releasing the center nut.
I was not that lucky. No amount of wiggling and WD40 would let me pull the wheel off without a puller.
If you happen to have a stable piece of metal, some bolts, a nut and a drill at hand, you can rig up a puller yourself.
Old Apr 20, 2011 | 02:11 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
If you remove the torx screws the wheel will come off. The torx screws hold the wheel to the hub. If you want to get the hub with it, you'll need to rent a puller. But for that style wheel, the hubs should interchange.
Old Apr 20, 2011 | 02:15 PM
MNformula350's Avatar
I have used a Rubber Mallet in the past to Remove Steering Wheels, But a Steering Wheel puller is nice (Have one now)
Old Apr 20, 2011 | 03:33 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Old Apr 20, 2011 | 06:39 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Puller is cheap. You may think it's a waste for one time use, but if you buy a balancer puller it will also work on steering wheels.
Old Apr 20, 2011 | 07:58 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I would not go banging, prying, yanking,or shaking on a steering column. Buy or rent a puller.
Old Apr 25, 2011 | 05:05 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
$21 and change to rent or buy a wheel puller. Good investment!
Old Apr 25, 2011 | 05:20 PM
mrcurl's Avatar
Car: 1985 silver iroc
Engine: L69
Transmission: manual
i say you forget about it, too much work. Just give me your friends contact info and ill buy the wheel.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
