Restoring interior plastic and carpet how-to
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Re: Restoring interior plastic and carpet how-to
I finally got ahold of a cargo plastic with cargo lid provision 'i already had a
cargo lid from a parts car'. The lid was tan and the plastic was charcoal.
Scrubbed them both up, sprayed them with adhesion promotor then the SEM
dye. Installed new carpet in the lid. I would have to remove the back part of
the exhaust and fuel tank in order to drill some holes for the cargo lid hinge.
Instead i am welding some studs from the inside. It should be ok since there is
no stress on the lid. Mockup...
What color SEM paint did you buy? I bought SEM landau Black, and it's a semi gloss, But almost looks too glossy, Was thinking of trying satin Black.
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I had tried this with some adhesion promoter I had and black plastic paint and after one week I tried scratching it and it was fairly hard to scratch. Then because of the piece it was on I tried twisting it and it still stuck but did have stress cracks. Even with the stress cracks it did not flake off. My idea was to see how it stood up to horrible abuse on this piece of miscellaneous ford plastic that I had. I will do it later if or when I need to.
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
Hey guys....can`t believe this thread is still going! Where are the sticky police?
Wanted to let you know tried some of the adhesion promoter and the lacquer on the mother of all tests for durability, a lexan RC car body! I could actually fold the lexan completely in half making a crease, flex it back to its original shape, and still was unable to scratch the paint off, even after a couple weeks of drying time. The lexan would actually tear before it would let go of the paint! It should hold up to our interior pieces no problems. How is everyone else making out?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I heard some stories about the bulldog adhesion promoter.. What is the best one? Camaro Central sells the "OER" brand adhesion promoter for a good deal (16.95$).
Also, there's a place that sells PPG paint that said they would need the paint code from the car, not the RPO code that GM uses for its interior paint colors. I'm going to call GM today to see if they have it but if they don't, this place said that they can't make the color of my interior because the car is too old (86) and it probably won't be in their catalogs. My interior color is the light saddle tan (beige) from an 86 camaro (pics of it are in my sig).. I believe they used this color from 85 to 87, does anyone know the RPO code for this color?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Sticky,Sticky,Sticky.Dooooo Ittttttttt.
Engine: 5.0 EFI
Engine: 5.0 EFI
Hellz_Wings,If you can get the RPO codes for you interior,BAPS Paints will match the code you give them.They use PPG Paints for GM car colors.There is a few members and I that have used BAPS to restore our interior plastics.They were dead on, on my Carmine.
Car: 1989 Camaro Iroc-z
I plan on doing some seat belt sleeves very soon. I have a local paint place that I go to for my exterior and that's spot on. What should I ask to get the interior color spot on? I also have the dark carmine in my '89
Wow that does look great .. I will give BAPS a call and see what's up! Thanks!!
And yeah, this is sticky-worthy IMO
Engine: 5.0 EFI
Engine: 5.0 EFI
Punkmaster98,what are you changing Black to Gray or Gray to Black??
Car: 1984 T/A
Engine: LQ4
FWIW the black looks MUCH nicer than the grey.. Maybe thats cuz ive owned so many cavaliers and it reminds me of them ... The panel came out gorgeous!
Engine: 5.0 EFI
Car: 1984 T/A
Engine: LQ4
it was a bit of trial and error to get it right. cold weather made one of the pieces dry dull so ive made sure i paint on a warm day. Joined: Nov 2010
Engine: 5.0 EFI
Engine: 5.0 EFI
No. 54 in this thread,O'Yea he is from another country,Ukrain. Last edited by mantaguy; Feb 29, 2012 at 07:41 PM.
I am almost done with my plastics. Aside from the fact that I had to replace most of them due to dry rot, they painted up nice with the paint I got from Baps. A lesson learned. A faded panel = dry rot = garbage.
I plan on buying extra carpet by the yard when I get my molded interior carpet and using that on the plastics. The backing on them is made to be molded with heat. So I am going to heat it up from the back with a heat gun and use my crappy interior plastics to mold it to. I haven't decided what to glue it with, but I am either going to use a hot glue gun or gorilla glue. I will let you guys know how it works out in a few months.
Here is one of the panels I painted with PPG paint:
I painted this with SEM paint. It has 3 coats of Landau black and 2 coats of low luster clear.
Overall, the SEM paint is easier to work with and more forgiving to what the panel's condition is to start out with. But they both finish really nice.
I think the key to the durability is definitely like Hawk312 said - the prep and the adhesion promoter.
Engine: 5.0 EFI
Those look terrific 82,are you painting your panels before you carpet or are you going to do what Hawk did and tape off the carpet.That guy Raceface used rubber glue for his.
I have all the carpet taken off my old panels. The replacement panels I bought didn't have the carpet on them. I was going to reuse them on the replacement panels, but I decided to try and put new stuff on them. I painted the whole panel, even where the carpet goes. To tell you the truth - I think it looks better without the carpet. But I am trying to restore the interior as close to original as possible, so I am going to put the carpet on again.
Engine: 5.0 EFI
Yea,I would keep it original also,try and trace the carpet from the old carpet pieces.
O yea, hows the paint job on your car coming along.
It's in the shop. The paint is stripped, and the painter is taking care of the minor body work it needs. I really should start a thread with some pics, but I want to wait until I get it back, and then I can put everything up all at once.
Just got everything I need today to start this. Do you suggest that I use a clear coat after I finish with paint?
Engine: 5.0 EFI
Not really,what type paint are you using.
Called GM vintage car department and asked the guy about the RPO code for my camaro and asked for my paint code and he said that it won't give the interior paint code.. He said that for the interior you have to "paint to match".. I told him that other people said otherwise and he said "No, there is no interior paint code".. This is the guy at GM telling me this LOL.. So I guess I have to bring a panel to a local shop that sells PPG paint and then have them paint it to match?
I looked through a catalog from 1989 when I was waiting for mine to be mixed..they had it in there along with several others as well!
I tried matching mine to the paint code and it was off. I had to send them a panel to match the paint.
As far as clear coat - it is optional. I just had this discussion with the manager from Baps today. He said that if you want to clear it, you must do it within 24 hours of spraying it, or you have to scuff and respray. If you use the car every day and think you might want the extra protection, then it might be worth it. I am going to clear my door sills and console bottom. I think the rest I am going to leave as is.
I asked him what type of clear to use and he said it did not matter. I think the SEM clear is good stuff. Low luster should give it the sheen it needs.
Joe - I am curious about that paint. I looked it up on the net and PPG Delstar seems to be some sort of acrylic enamel. Did they tell you it was okay to use that on plastic?
I think you should be OK as long as you use an adhesion promoter. As far as clearing it, you should probably ask the guys where you bought it what is compatible with it.
I dont see why not.. I gave him a piece of plastic that broke off of my original and he matched it up perfect and kept asking me what I was using it for. I also picked up sandpaper and that adhesive promoter as well. I also have some clear coat laying around as well just in case. It should work alright.
Engine: 5.0 EFI
This is what a few of us had used on our Carmine Plastics with good results.
It appears that the nos are the same.
Engine: 5.0 EFI
joekonik,how much was it a can and how many did you get.
Engine: 5.0 EFI
The color codes may be the same, but those are 2 different PPG products. The one he bought is an enamel based paint. I am not sure if it is any better or worse then what we used, but it is definitely different. I think PPG Deltron DBI is a urethane based paint.
I went here because it only costs 20 bucks for them to make you any paint you want in an aerosol can. I didnt wanna spend big bucks on something many people wont really notice. Almost all of my trim is mint except the seat belt sleeves. I only got one can for now until I see how it turns out
Engine: 5.0 EFI
Yea,I hope it works out for him.
Engine: 5.0 EFI
Yeah that's what I figured. I'm trying to save as much coin as possible. They should be done by tonight hopefully. Then I'll have pictures up if I'm satisfied lol
Well I just finished! Turned out a lot better than I expected...the two outer ones are the ones I painted. The one in the center is the original thats falling apart
Engine: 5.0 EFI
Now they were black right?did you use clear coat on them.Junior Member
Yeah they were black. I was worried at first because it kept showing through but after a few coats it went away. I didnt put a clear on them because this paint made them a little glossier than the original..but not by much. The color is also close but its a little darker..but that should match up to my leather perfectly, so I dont care
Engine: 5.0 EFI
I noticed they were a tad darker,once you put them back,you won't even see them.
I want to get the SEM Landau Black to do my carpet and plastic. From what I gather. Will the [SEM Colorcoat - Landau Black] work for both carpet and plastic and still look pretty close to stock?
I just dont want there to be a big diff from my other black pieces
Should I use the adhesion promoter on carpet also?
Thanks for the thread, amazing!
If you are doing the dash and console pieces, the Landau black will be fine. But I think it might have too much shine for the rear plastic trim pieces. It should also work for the carpet, but you need to brush it as you do it, or the carpet will get stiff. Don't use adhesion promoter on the carpet.
This is Landau black on my center console top.
That black looks great on the console, does that match your black dash? If so, I have a console I'll be doing also, so I'll buy some SEM Landau black for that and the carpet.
Now for the rear plastic, What does anyone recommend for them? I'd get get the interior GM paint code mixed somewhere if thats the only choice I have, but I've got some Rust-O-Leum Satin universal paint I'd like to try, but I'm scared it wont match my door trim pieces and dash.
What's a nice alternative for a close match? Thx people
