Wobbleing stearing wheel
Old May 9, 2011 | 02:49 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Well i bought a 86 T/A and when i bought it thew steering wheal wobbles a lot, when i turn the steering wheel the wheels do turn but when i grab it and shake it it moves a lot. my dad says that it might be a bearing in the collum thats is shot, but i cant really find anything altho i think its because im not looking in the right thing. i believe that its a tilt collum if that helps, and if anybody thinks it its repairable, or am i up creek and need to buy a new collum.
Thanks in advance
Old May 9, 2011 | 03:00 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: Wobbleing stearing wheel
Sounds like the bolts that hold the upper halve of the column on are loose. It is a very common problem with the Saginaw column. In order to repair it you will need a few special tools that aren't very expensive. You will need steering wheel puller, lock ring depresser, pivot pin puller and internal and external torx bits. You can get away with out some of the tools like the wheel puller and pin puller. The repair is not very difficult but time consuming and difficult to explain. Mike
Old May 9, 2011 | 03:17 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
ok sweet, i actually would only need to get 2 of those tools, since i have the others. but will there be anything i should look for in the way of damage or anything? if i find an exploded view or something in my chilton manual will that help?
Old May 9, 2011 | 04:26 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Are you sure the tire(s) aren't messed up? An air pocket in the rubber will make the wheel shake while driving.
Old May 9, 2011 | 04:41 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
try: https://www.thirdgen.org/forums/faq-...eels-like.html
Old May 9, 2011 | 08:08 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
well ive never driven the car(long story short it was doner car that turned out to become the project) but when i grab the wheel i can shake it all around. i think i would be a little to scared to drive it like this. altho i know ill need to so some suspension work but thats for another time. i might not be explaining it right but when i sit in the seat i can turn it and the wheels will turn normally, just if i just shake it the steering wheel will shake. not i did notice that the lock on the column looks busted out which may also have something to do with it. im sorry i didnt mention it earlier, ive only had this car for about a week(it was one hell of a deal, 300 for a TA that just needed a tranny, engine and a passenger side window)
Old May 10, 2011 | 06:29 AM
naf's Avatar
naf
Read thru the link I posted? The four bolts that attach your column to the tilt mechanism are loose.
You can rent the puller and lock plate remover from AZ.
Old May 10, 2011 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You may find something valuable in the following link:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
FormulasOnly
Sep 6, 2015 10:42 AM
