1991 trans am door panel
Old May 19, 2011 | 02:01 PM
cosborne's Avatar
First off let me say I am new and this is my first post. I am trying to remove the door panel because the power lock buttons are not working. I am having trouble removing the plastic part around the door handle. It looks as though there is small round cover that could popped off and a screw may be underneath it. I want to make sure that is what it is or if there is something else I am missing. I can' seem to get it to pop out. I do not want to keep trying if it is not suppose to come out.
Old May 24, 2011 | 03:34 PM
stshstsh's Avatar
Re: 1991 trans am door panel
post a pic of what you got and point out the trouble areas?
Old May 24, 2011 | 09:06 PM
cosborne's Avatar
Attachment 219785
I need to know if the small circle behind the handle pops out. This is only place that I can't get to pop out, there are no screws anywhere else on the handle. The pc that has the bird on it pops out but there is no screw behind it.
Old May 24, 2011 | 10:07 PM
stshstsh's Avatar
is it for the window crank or the actual door latch
Old May 25, 2011 | 07:13 AM
cosborne's Avatar
It is the door latch, There is no window crank it has power windows. I have the arm rest and cup holder off but I cannot get the door latch which is the picture in the attachment off. If you notice in the picture there is a small section with a bird on it, that part pops out but there was no screw behind it. The only other option I see is the small circle but it is not wanting to pop out.
Old May 25, 2011 | 06:07 PM
stshstsh's Avatar
the link for the pic doesnt work, i forgot to mention it
Old May 25, 2011 | 08:42 PM
cosborne's Avatar
Attachment 219850
The circle is behind the door latch.
Old May 25, 2011 | 08:44 PM
cosborne's Avatar
I'm not sure what i am doing wrong with this picture. When I preview the post it shows my picture but now it has a link. When I click the link the picture shows up not sure if it will work for you or not.
Old May 25, 2011 | 09:11 PM
stshstsh's Avatar
email if ya like: stshstsh@gmail.com
Old May 26, 2011 | 01:21 PM
MNformula350's Avatar
Yes, the Round Black Cover can be popped off, and there is a Phillips Head screw behind there, Remove the Screw, and the Handle trim Panel can be removed.
Old May 26, 2011 | 05:57 PM
stshstsh's Avatar
yup hes right, i took a look at mine and i thought you meant there was a circle thing behind the entire door panel, and when i took mine off i didnt even think that is the one you were talking about. but apparently some people have rivets? and they had to drill theirs out.
Old May 26, 2011 | 07:52 PM
cosborne's Avatar
Ok thanks, I assumed that is what it was but it was not wanting to pop out. I will give it another try,
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
