still having hatch pull down problems
Old Jun 10, 2011 | 11:16 PM
no_limit5869's Avatar
i am still having troubles with my hatch pull down it went up when i replaced it but now it wont go back down and idk y is the switch suposed to have power going to it anyways plz help me i have have some pics of the wiring
http://imageshack.us/photo/my-images...181403499.jpg/
http://imageshack.us/photo/my-images...181415586.jpg/
http://imageshack.us/photo/my-images...181425610.jpg/
http://imageshack.us/photo/my-images...181441851.jpg/
http://imageshack.us/photo/my-images...181449866.jpg/
http://imageshack.us/photo/my-images...018145979.jpg/
http://imageshack.us/photo/my-images...181520405.jpg/
http://imageshack.us/photo/my-images...181534513.jpg/
http://imageshack.us/photo/my-images...181542605.jpg/
Old Jun 10, 2011 | 11:44 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: still having hatch pull down problems
Wiring looks fine. The white wire with small black connector doesn't connect to anything for your model year. It was used in late 89 thru early 91 only to provide a switched ground to turn on and off the hatch light.
Unplug the large white connector on the blue wire that plugs into the red/white stripe wire. Check that the red/white stripe wire has power. If so, then the problem is either the striker-sensing switch or reversing switch.
Someone has replaced the original motor with the new style motor, which is a direct drop in replacement for the original motor and separate clear plastic motor housing.
Lon Salgren
Old Jun 11, 2011 | 12:04 AM
Lon Salgren
yes that was me i replaced it cause the old one went out 6 years ago jus now replaced it and now having this problem and it has power i checked with a test light and witch is the striker sensing switch
Old Jun 11, 2011 | 12:09 AM
lonsal's Avatar
You're holding it in this photo.
It attaches in front of the latch (as you look at the latch from the rear of the car) with a single hex-head screw.
The striker-sensing switch starts the up or down cycle. The reversing switch ends the up or down cycle.
Lon
Old Jun 11, 2011 | 12:37 AM
is that switch that i am holding suposed to have power goin to it i checked the orange blakc and white wires and non of them have power
Old Jun 27, 2011 | 10:21 AM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
Lon Salgren
I having same problem. Does the red/white have power all the time? When center console button is pushed?
Old Jun 27, 2011 | 10:34 AM
lonsal's Avatar
First, let me explain that my description of the problem and possible soltution only apply to the 86-early 91 hatch pull-down unit. That style of pull-down unit is what is shown in OP photos above.
Now to your answer. The red/white stripe wire has constant 12 volts. When you refer to pushing the button on the center console, that is the optional hatch release button to trigger the hatch release solenoid. That is powered on a separate circuit. The power wire in that case is black with a black connector on the end that is plugged into the end of the hatch release solenoid. It is only energized when the button is pressed. There is a separate ground wire with a serrated ring-terminal on each end that connects to the 10mm screw attaching the solenoid to the latch assy. The other end of the ground wire connects to the body ground location below the pull-down unit. The ground wire MUST be in place or the solenoid won't work since it it electrically isolated from ground by the guides in the track.
Lon Salgren
Old Jul 8, 2011 | 12:03 PM
Guest
Guest
Posts: n/a
This '86 I just bought a month ago, it wouldn't finish closing the rear hatch.
I opted for a quicker, cheaper and easier solution. I un-bolted the little electric motor, then adjusted the sliders down to where it looked like they normally stopped. Next, I drilled some 1/8" holes through the sliders and their tracks, and put screws through my new holes.
Then I test-closed the hatch very gently. The height was still 1/8" up, so I re-did those last few steps. This time it sat right, so I drilled more holes and added more screws. Lastly, I unplugged the wiring from the motor, and replaced the trim.
A free, permanent solution.
Old Jul 10, 2011 | 02:37 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
have you had any issues with rattling or squeaking from back there?
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
