200 for a stock t/top headlinerworth it?
Old Jun 29, 2011 | 10:37 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
Hi all, i have been searching for a t-top headliner used to no avail, the other day i found one thats my color mint with the t/top covers, center roof consule and speaker covers for $200, is this a good price or is it too high for a 23 year old headliner? thanks in advance...
Old Jun 30, 2011 | 09:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 200 for a stock t/top headlinerworth it?
Well your going to spend $200 plus shipping on a new one,headliner only,so that's not a bad price for what all your getting,I'm thinking you are calling the sun shades T Top covers,their $60.00,plus a roof console I don't know what their worth.plus sail panels,If you say their mint then buy them.
Old Jun 30, 2011 | 09:13 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
But, you will be buying 23 year old foam backer. I would pop for the abs kind. You will save $ in the long run.
Old Jun 30, 2011 | 09:22 PM
mantaguy's Avatar
Engine: 5.0 EFI
I agree,That's what I did,but he said it is in mint condition.I spent $199.00 + shipping for a ABS type alone.
Old Jul 1, 2011 | 09:35 PM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
thnaks for the replys, we will see what happens...
Old Jul 3, 2011 | 04:06 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Personally I would buy a new ABS. GM should have made them ABS from the beginning. The cardboard and foam you are buying is still 23 yrs old and will rip and crack eventually. Its just not designed to last.
Old Jul 8, 2011 | 07:38 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the only thing i'd be concerned about is the foam disintegrating (like others have mentioned). it breaks down over time and ends up sagging. Some opt for the new abs ones while others scrape the old one and recover them. I'm going to be redoing mine, but will be reinforcing it with some fiberglass too (since the fiberboard can fall apart if it gets wet).
Old Jul 8, 2011 | 08:42 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
why not jsut have your board recovered? mine only cost me $123.09 to have it covered.
Old Jul 8, 2011 | 09:15 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yeah, but you also have a hardtop that doesn't generally leak like the t-tops do... And the t-top liner is more than likely more expensive to have recovered due to the labor and time to get done properly in the corners.
Second, there are posts on here that the ABS headliners generally don't fit right.
Personally, since I'm probably going to end up doing fiberglass work anyways, I think I'd rather learn to make my own fiberglass backer and not worry about that cheap POS fiberboard backer falling apart again (mostly because I no longer have my backer as I tossed it due to this). Then I'll either cover it or have it covered professionally (going to miss those leopard print buttons, though).
Old Jul 9, 2011 | 03:57 PM
Prostreet87Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: Manual Valve body TH 350
i went to michaels and bought material called black headliner... cost me like 20 dollars to recover my T-top headliner its pretty easy to do. if you want it to last longer put some fiberglass resin around the corners or just coat/cover it in fiberglass before you recover the thing in headliner. costs you alot less if you do things your self.
zerogsx
Feb 6, 2016 11:29 AM
LT1Formula
Nov 16, 2015 01:13 PM
Genopsyde
Oct 7, 2015 08:35 PM
MoJoe
Sep 24, 2015 09:12 PM
Out-Cast
Aug 23, 2015 06:33 AM
