wanted 85 shifter plastic movement rod
Old Jun 29, 2011 | 10:56 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
it needs to have a hole in it for the button to clip into, it is the ball with the center button, i know these are htf, hoping someone has a shifter laying aroung i can get the rod from, it is flat with a hole in it.
Old Jun 29, 2011 | 11:01 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
Re: wanted 85 shifter plastic movement rod
I found one in an IROC today at a junk yard. I need to go back to get some things. If it is still there I will let you know and we can work something out to get it shipped to you. I think the car was an 87' though. It was the whole shifter ****.
Old Jul 2, 2011 | 06:25 AM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
i am unsure if that will be the type i need, if you can take a pic i would be greatful
Old Jul 2, 2011 | 01:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Should'nt this be in the classifieds? Might have better luck.
Old Jul 2, 2011 | 01:30 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 13, 2015 07:36 AM
