Hatch motor relay click but not doing down?
Old Jul 3, 2011 | 07:55 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
OK, I bought the hatch motor pulldown rebuild kit from Hawks and even went as far as replacing the relay however. the motor will go up but when I push the latch sensing switch so it will go down nothing happens. The relay clicks but doesnt go down. I also noticed the motor is hot after a few minutes. What am I doing wrong here?????? Please someone help me out!!!!
Old Jul 6, 2011 | 09:04 PM
grasshoppertym's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 limited slip
Re: Hatch motor relay click but not doing down?
if the motor is getting hot it is trying to move but is unable to. is something jamming the gears? or maybe the motor has a dead spot and just doesn`t have the abillity to turn...kinda like when a starter starts to die
just a thought
Old Jul 8, 2011 | 03:34 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Can you take a look at your locking mechanism on the side that goes toward the rear. There is a wiring harness with three wires; black, orange and white. Can you tell me what order they're in from left to right? Thanks!!!!!!
Old Jul 9, 2011 | 04:03 PM
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
look at these pics and see if it helps. if i can upload that is...stand by i`m having issues
Old Jul 9, 2011 | 04:17 PM
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
black is on the right side (pass side) looking down
orange is next to the black
and the white is on the left of the orange
i also have a blue wire on the far left (driver side) not sure if it is for the power locks or not but i have taken some pics of all the wiring around the pulldown motor but they are not uploading but if you send me your e-mail i can send them that way .... hopefully
mike
sorry i went right to left
Old Jul 9, 2011 | 05:05 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Thanks for the info. I appreciate the help!
Old Jul 9, 2011 | 10:55 PM
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
hope it helps, i have gotten help from this site before so anytime i can give some back i will
if you need those pics just let me know
mike
Old Jul 10, 2011 | 05:58 AM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Your suggestion did help. I tried to solder the wires in place with marginal success. I got it to work but I'll probably have to end up buying a new wiring harness. Thanks again for your help!
BRoss99
Aug 10, 2025 05:08 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
