Camaro to Firebird Wheel Swap
Old Aug 18, 2011 | 09:31 PM
logan90us's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.7L 350
Transmission: Automatic
Soo I love my 91 Bird, but I hate the stock steering wheel. It's so thick and just uncomfortable. The one thing I really miss about my '88 Camaro was the wheel, it was nice. Would a wheel from a Camaro be able to take the place of the one i have now?? If so, what would I need to get it installed?
Old Aug 18, 2011 | 09:43 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Camaro to Firebird Wheel Swap
yes they will and you need the new steering wheel and a wheel puller
Old Aug 19, 2011 | 03:08 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the same splines were used across quite a few gm vehicles, so fit should be ok. however, in case i'm remembering wrong, your 91's got an airbag and the 88 doesn't. If that's the case, you may not pass inspections due to the removal of mandatory safety equipment.
Old Aug 19, 2011 | 06:06 PM
logan90us's Avatar
Engine: 5.7L 350
Well that's good to hear. Aww yeah there are ways to pass inspection. :-p
Old Aug 23, 2011 | 09:16 PM
88gunmetalgta's Avatar
Keep a firebird wheel on it. I like this style from the earlier third gen 'birds:
Old Jan 21, 2014 | 05:33 PM
transamch's Avatar
Car: 1985 and 1991 Trans Am
Engine: 5.0 TPI and 5.0 TBI
Transmission: TH700
Hi!
Nice looking steering wheel in the 91/92 TA.. Want to make the same..
Did you modifie the steering column or something to fit the old steering
wheel in the 91/92 TA?
Thank you for answer
Old Jan 22, 2014 | 12:52 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Did the same thing with my '91. The earlier steering wheel is a direct fit, just clip the horn wire on, match up the splines, tighten down the nut, and you're good to go. You will have to clip the yellow airbag wire to get the wheel on, but otherwise it's very straight forward.
Old Jan 22, 2014 | 01:06 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
OK 88, the inst. panel red inserts are really cool.
How was that accomplished?
Old Jan 22, 2014 | 04:02 PM
transamch's Avatar
Transmission: TH700
i read something about you have to "cut" some of the plastic away.. is that true?
Old Jan 22, 2014 | 10:32 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
I can't comment on anyone else, but I had to trim about 1/8" of material off the bottom of my early 'Bird wheel I put on my '91 'Bird to not have it rub on the column.
Old Jan 23, 2014 | 04:06 AM
transamch's Avatar
Transmission: TH700
can you show us a picture? Would be nice to know if you can see the modification..
Old Jan 23, 2014 | 07:07 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Here is a bad one. If you look close you can see I didn't get it quite level at the top.
Someday I'll do another and be a little more careful.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
IroczFan
Oct 6, 2015 10:13 AM
