Dash pad crack - fix?
Old Sep 13, 2011 | 08:26 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I know there are a million threads on fixing the cracks in the dash pads, but I'm just looking for a way to stop it from spreading. I attached a picture of it. This is the ONLY spot on the entire dash pad.
Thanks!
Old Sep 13, 2011 | 08:41 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Dash pad crack - fix?
read this whole thread... the dash I have in my car had similar damage to yours
https://www.thirdgen.org/forums/inte...on-thread.html
Old Sep 13, 2011 | 08:45 PM
chevydrvr's Avatar
I actually have seen that thread before, I didn't think of it until now. I could just use that epoxy that you used. Where can I get it and what is it called?
Old Sep 13, 2011 | 08:46 PM
58mark's Avatar
evercoat maxim. a seller on ebay is selling it cheap at the moment. Let me know if you can't track it down and I'll find a you a link
Old Sep 13, 2011 | 08:49 PM
58mark's Avatar
aw, here's the link... saves you the time of looking
http://cgi.ebay.com/ws/eBayISAPI.dll...K%3AMEWNX%3AIT
bubbagump2001's Avatar
Car: 1989 Iroc Z 28
Axle/Gears: Stock
I had mine crack in the same place. Used some black RTV filled it in and smoothed it out with my finger.
Old Sep 13, 2011 | 08:51 PM
chevydrvr's Avatar
Thanks, I had actually just bought the link you posted. I'll post pics after I fix it.
Old Sep 13, 2011 | 08:52 PM
58mark's Avatar
great! good luck. I love the spray on bedliner to cover the fix. it's the right color and texture for these pads
Old Sep 13, 2011 | 09:33 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Theres also a place in PA called "Color plus" they are a leather repair company. There is an article on thier site about repairing dashpads I was thinking of trying, looks promising. I've used thier leather products before on my Corvette and it was excellent.
Old Sep 13, 2011 | 09:41 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
SEM has a texture spray that is probably a little better to use than bedlining.
Old Sep 25, 2011 | 12:15 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
To stop the crack you need to drill holes at the both ends of the crack before you repair it..goodluck
Old Sep 26, 2011 | 06:51 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Do you think this would work to fill in cracks? I plan on wrapping my dash with simulated carbon fiber, instead of buying a new one, but I need something to hide the cracks so it's not seen through the carbon wrap
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
