ARM REST WITH DRINK HOLDER WITH RED RING
Old Oct 10, 2011 | 03:48 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Anyone tried one of these from Classic, any installed pictures?
1982-92 ARM REST WITH DRINK HOLDER WITH RED RING
Add the cup holder that GM left out of the 3rd Gen F-Body with the HoldsterTMArmrest replacement. This is NOT a plastic cap, but rather a new padded armrest and King size drink holder complete with mounting screws. Installation is simple, remove your old armrest from the factory hinge and mount the HoldsterTM to the factory hinge using the 3 enclosed screws. Upholstered in black vinyl and comes with a matching black drink holder trim ring to match the original vinyl of your interior. Want to customize the HoldsterTM with to match your car? Choose from 4 different color-coordinated cupholder trim rings (red, blue, silver, or gold) to create your own look
http://www.classicindustries.com/cam.../hh1011rd.html
Old Oct 11, 2011 | 07:46 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: ARM REST WITH DRINK HOLDER WITH RED RING
well....its an armrest which means it will be in the way of your arm resting there.i drilled a 3.5/8 hole in my console behind the window switches and stuck a drink holder insert in there.it was always in the way of my arm.
Old Oct 12, 2011 | 02:18 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
Could you post a picture of this I never thought of doing that.
Old Oct 13, 2011 | 10:28 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
search does wonders......
Old Oct 13, 2011 | 10:52 AM
zenish's Avatar
Engine: 305 tbi
i no longer have that car but someone else on here did the same thing and posted pictures.
Old Oct 14, 2011 | 12:36 AM
AdamsRS25's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I have one in my 92 RS works well enough, but latch mech. has to be removed to install. It is heavy enough not to be a big issue.
Old Oct 14, 2011 | 02:05 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I like the idea but it only has one cup holder and you will have to remove your drink to get inside the center console. I like the Uncle Tom version better because it keeps the center console stock and creates two cup holders.
https://www.thirdgen.org/forums/inte...p-holders.html
Old Oct 14, 2011 | 02:26 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Their are abunch of different options
https://www.thirdgen.org/forums/inte...termarket.html
https://www.thirdgen.org/forums/fabr...der-looks.html
http://www.customcorvetteaccessories...upholders.html - i like these
https://www.thirdgen.org/forums/inte...r-install.html -here is a a good write up
https://www.thirdgen.org/forums/inte...holders-w.html
and so on...
Old Oct 26, 2011 | 07:29 PM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
I think that cup holder/ armrest will cover you window switches and other that are there. I have five switch there.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
