I want to see your custom gauges and other interior mods!
Car: 1986 Trans Am
Engine: 350 SBC
Re: I want to see your custom gauges and other interior mods!
I like my interior mostly stock, but just installed my custom gauge rings from Luis (motobooks) and I love how they look on my '86!
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Not everyones favorite interior but whatever. Will have autometer cobalt series afr and nitrous press gauges in the pods along with a custom shift light location.
But heres what i started with
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 91RS
Engine: All Forged 350 .40 over
Transmission: Built Monstertrans 700R4 Manual Val
Axle/Gears: 10 bolt spooled w/ 355 gears
Alright, heres my interior, take a look i need advice on gauge and gauge clusters. Maybe someone would like to make a custom housing or gauge pod?... let me know wgat you guys think please. Its a 91 RS. More pics in profile
Car: 91RS
Id like to go digital, wether it be intellitronix or anything. Im looking for an aluminum instrument housing that fights intellitronix digi gauges, all i can find is this
http://www.camarocentral.com/mobile/...ctCode=DAS-393
Which is nice but it has 5" holes for speedo and tach and intellitronix are only 3" :/ .. On the other hand Autometer. Elite gauges are also catching my eye, i just need a cool freaking gauge cluster housing......
any help advice and suggestions are welcome.
Car: 91RS
Bump
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
Neweraracer which grant steering wheel is that i am looking for one just like that!
Did you do that yourself or order it from someone? And what kind of problem was it wiring it in?!?!
Car: 91RS
None that i recall, i just left all the electronics delete and didnt connect the horn.
I ordered the steering wheel from here
http://www.grantproducts.com/products/view/19/
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it did have 4th gen seats, but i'm using a kirkey on the driver's side now, which is actually sitting even lower than the 4th gen seats. the kirkey is basically on the floor. i have no problems seeing what i'm doing:
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Car: 91RS
Lol yea its a little loose i thought about dropping a few drops of super glue in the crevice but aint got around to it
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Car: 91RS
No, unfortunately i cant take credit for that, i designed the theme and chose colors and leather but had a local upholstery shop do the front and back seats. The only thing i did were the panels, head liner and carpet
Car: 91 Camaro RS
Engine: 383ci, Holley 750cfm carb
I built this one for my '91 Camaro, I haven't installed it yet
Car: 91RS
What size Speedo and tach holes?
Car: 91 Camaro RS
Car: 91RS
Want to sell the housing without the gauges.
Car: 91 Camaro RS
Car: 91RS
Ok, if any one has one for sale let me know
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I changed the backlight to blue, added a 140mph speedo and changed the needles from orange to white
First I converted the back of the gauges from orange to gloss white
Then I taped off and did the same with the front bezel. I also repainted the front part black.
Then I painted all the needles white
I used these bulbs for the blue back light 194 wedge bulbs with 5 LEDs
My first time lighting it up I found too many cold spots.
There were some empty spaces in the cluster so I scraped the mask from the traces and added more bulbs. here is the final result
I am really pleased
I am really pleased
Car: 1987 irocz
Engine: 5.0 305 tpi
Transmission: stock auto
Axle/Gears: stock not sure the ratio
what year did Camaros/trans am's have cup holders on the doors
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Never an option on Camaros.
Thats a f.b, t/a option (88-up, i think) & not available w/ maual windows.Not availble on GTAs either & whatever other stipulations may be.
Car: 1987 irocz
Engine: 5.0 305 tpi
Door panels are interchangeable between trans am / firebird to camaro? Like if i found those panels would they fit my doors i have power everything so
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, or you can keep your panels & just use the cup holder.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
From Firebirds & Trans Am yes unless it is the Deluxe Interior like in the GTAs with their different arm rests. Those can be swapped in if you add the extra bracket that changes the arm rest mounting screw positions from the bottom to the sides.
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
A while back i bought some single leds. Blacklight ones and pure white ones. I popped off my headliner and burnt through it through the backsid . Inserted each led in a random pattern.. wired each individual color together.. then to a switch.. and vwala. Dome lights and party lights in one lol
Car: 86 Iroc
Engine: 420HP/440FT-LB SB355
Axle/Gears: 10 Bolt 3.73
Here are a few from my build. Used the 3M Carbon Fiber vinyl, and plexiglass, cut to size and there you have it, nothing too extravagant! Other gauges are on the pillar.
Car: 1984 Trans Am
I just realized I've never posted my gauge rings!
Car: 92 Z28 Hawaiian Orchid
Axle/Gears: 3.23 Posi
Can't wait to make mine soon ! Also make my aluminum shift plate for my th350 , aluminum door piece that holds the unlock/lock buttons ( deleting the buttons and making a solid piece with cut outs for the handle and locking lever ) & cluster bezel with toggle switch inserts ! And adding removable steering wheel with red stitching ! Hope to be done in the next few weeks
Transmission: Pro-built 700R4
Car: 1984 Trans Am
Car: 1988 Camaro
Nordskog digital gauge panel, Cyberdyne oil temp, trans temp and a/f ratio gauges in driver side vent holes.
B&M pro stick shifter fabbed up as a console fit
Auto Meter fuel pressure and vac gauges mounted in the harwood 4" cowl hood
S&W 10 point roll cage
Ebay sport/race seats fitted to oem sliders
Grant classic steering wheel
Toggle switches on console for aux. elec helper fuel pump, and th-400 elec kickdown/detent
Not shown in those pics. Linelock button mounted under chrome skull shift ****, Mallory digital ign. box mounted on pass. side front of dash.
Horn tweeters in dash, 6x9" speakers in oem sail panel loc. and 2 12" subs mounted on a plate in the rear
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Some really nice Mods on here.
Mines just a small one but one you don't see often. Some 6.5" door speakers that sound really good with the Kenwood deck and Pioneer 6x9s on the Sail Panels.
