View Poll Results: Swap guts or not
Keep the manual stuff and ditch the power
100.00%
Swap the guts and risk messing up the manual doors
0%
Just swap the window motors (one door lock dont work)
0%
Voters: 10. You may not vote on this poll
Swap power windows, or leave manual (new doors)
Old Jan 1, 2012 | 10:20 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I just ogt me some super nice doors off of a V-6 firebird. They are all manual. The doors in Z28 are all power (except mirrors). They new doors have tight handles, the tightest factory third gen door hinges, and the manual windows are silky smooth. No play in the glass when rolled up either.
So here is my question, do I go throught the pain of swapping the guts of the doors to get power windows and doors locks? Or just leave them alone and put the plugs into the holes from the donor car?
Old Jan 1, 2012 | 10:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Swap power windows, or leave manual (new doors)
The power windows suck,their to slow,to many different very hard to find parts to replace when they go.If the ones you have are good then keep them.
Old Jan 1, 2012 | 10:38 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
when I was shopping for a third gen I made sure to get a manual window one, just to avoid problems in the future
Old Jan 1, 2012 | 10:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
I know what you mean Mark,I have power windows and they are very slow going down,it feels like your going to blow a fuse before their down.
Old Jan 1, 2012 | 10:55 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Manual is the only way to go! Electric motors go out and it is a pain to switch.
Old Jan 1, 2012 | 11:11 PM
87ohcamaro's Avatar
Car: 87 Camaro
Manual all the way. So much easier in the long run
Old Jan 2, 2012 | 02:31 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Ive replaced mine and swapped them into friends cars. It isnt that hard to do but can be a pain. The way I see it is leave them manual and throw all the wiring into the doors and see how you like them. If you dont strip your old doors and put the power windows back in.
Old Jan 2, 2012 | 09:09 AM
supr_fly03's Avatar
Car: 83 Z28
Sounds like it is better to just throw the "new to me" manual doors on the car and go. I will strip the power stuff out of the old doors so I can always install it later.
Old Jan 2, 2012 | 10:57 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
idk about you guys but my driver side manual window is really hard to roll down and up when it gets about half way down it gets really hard like it doesnt want to roll, and coming up its hard till after halfway
Old Jan 2, 2012 | 11:16 AM
supr_fly03's Avatar
Car: 83 Z28
Pull your door panel. Lube up the slides and gear/spring the handle is attached to. Should work much better after that.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
