Door trim
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Door trim
The plastic trim that runs under the window and one runs across the roof right above the window (with the door shut) on my car is starting to come off, what holds it on? I didn't see any screws so I'm not sure how to put it back on
Car: 1989 Camaro RS--
Engine: MPFI
Re: Door trim
I have seen this question so many times. I wish someone would give a detailed answer. I have a new head liner I want to put in, but would like to know how the upper door trim comes off. So all you guys that know the answer, give it up!
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Door trim
I'm not sure what it's called, the top one runs from the windshield and back along the ceiling right above the door, and the bottom runs right below the window, my car has a red interior and this trim is black, if that helps
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Door trim
That's the A puller trim. It's held in with clips. It's a PITA to get them out so most people just break them then replace them
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Door trim
OK its been a long time but I beleave you slide the trim back and down.
I also found this thread = https://www.thirdgen.org/forums/inte...g-removal.html
Reply #13 says the same thing
Engine: MPFI
Re: Door trim
That's a drag, D**n i really don't want to replace them. Has anyone been able to take off without breaking them? I know i have read that double sided 3M tape can be used to reattach them.
Engine: L31 350
Re: Door trim
you can buy the clips to replace them or you can test your pacience on trying to remove them
Car: '92 Camaro RS
Engine: 305 tbi
Re: Door trim
For the plastic below the window, you would have to replace the cardboard-ish piece inside the door. If you take off the interior door trim, you will see that the plastic is being held on with pegs going into holes in the cardboard panel. Over time the cardboard breaks apart, leaving the plastic loose.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Door trim
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: Door trim
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
